Old 01-14-2025, 07:32 PM   #1
Incognito-A
Default Australian Seat Springs
I was told that these seats were possibly carried over into some of the 1933 models. Pictures are from Australian 1930-32 Sports Phaeton. I’m in need of the backrests to buy outright or borrow for patterns.
Incognito-A is online now   Reply With Quote
Old 01-14-2025, 08:00 PM   #2
paul2748
paul2748's Avatar
Default Re: Australian Seat Springs
Are you looking for a U. S. car or a Australian one. For a U S car, Snyder Antique Auto Parts made springs for early fords. It's been awhile since I had any business with them, but the last number I had was 330-549-5313 for tech info. Reg # 888-262-5712. They are located in Ohio
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-14-2025, 08:17 PM   #3
DavidG
DavidG's Avatar
I doubt that the '32 Australian phaeton seat back cushion springs are carried over from those in a Model A phaeton, let alone on into the Australian '33 phaeton, given that each model year's phaeton body is very unique from one another.
Old 01-14-2025, 10:55 PM   #4
Incognito-A
Each of the above pictures shows the Australian built “Sports Phaeton,” a completely unique body produced in the 3rd quarter of 1930 through 1932. Both the front and rear seat backrests are the double cushion design. I own a 1930 Sports Phaeton, one of the first 99 produced in 1930. I need the backrests.
I don’t know anything about the Australian early V8 production. Maybe someone has the Australian body parts book from 1932/33 and can look for the part number progression. I’m going on a tip from someone on another facebook forum.
Old 01-15-2025, 08:47 AM   #5
Karl Wescott
Karl Wescott's Avatar
I believe that Snyder's will custom make seat springs if you supply a pattern or specifications.
Carline Manufacturing, Beaumont TX (409) 833-9757 also will make custom seat springs. Note Carline is NOT affiliated with "the other guy" in Beaumont.
Karl Wescott is offline   Reply With Quote
Old 01-15-2025, 08:54 AM   #6
Incognito-A
If I had a pattern or specifications then I wouldn’t be desperately searching the earth for a set. I’m capable of making the springs myself if I had a pattern!
Old 01-15-2025, 09:10 AM   #7
uncle buck
uncle buck's Avatar
Originally Posted by Incognito-A View Post
If I’m capable of making the springs myself if I had a pattern!
Jeez... Karl tries to help and you yell at him.
uncle buck is offline   Reply With Quote
Old 01-15-2025, 12:20 PM   #8
Incognito-A
Thank You for the suggestion Karl.
(!) was for emphasis. Generally the convention is “ALL CAPS” is considered “YELLING”
Old 01-16-2025, 03:01 PM   #9
FlatheadTed
FlatheadTed's Avatar
Try some of the Kiwi members on the Model A side ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
