Hello all. Recently got a 29 Phaeton. It has a side mount spare; I’d like to have a spare in the back also. I see spare tire mount brackets for sale, but they have three bolts (unless I’m viewing something wrong), and the rear of my phaeton only seems to have two bolts in that area. What am I missing here? Thanks!
My '28 has 3, two at the bottom, one in the body.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 455 5 speed Restomod 1976 MGB -Life's Too Short To Drive Boring Cars- |
The bolt at top goes through a curved re-inforcing brace inside the body. Without that brace, the heavy weight of the spare tire carrier plus the wheel and tire would pull outwards and bend the metal center panel. Don't even THINK about putting a bolt through the center panel without that all-important inner brace! You'll pay a fortune in body shop charges to repair the bowed-out center panel, which dents and bends very easily.
Marshall |
#4 | |
![]() Quote:
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. Last edited by Synchro909; 10-21-2024 at 06:04 AM. |
#6 | |
I have a couple of original spare tire braces on the loose. Tomorrow I'll remove the rear seat cushion in my 1928 Phaeton and see if that brace is visible and then compare it against my samples. If any of them match the contours of my Phaeton, you can have one for the shipping cost to you. I kind of think, though, these are most likely from a coupe or roadster. I wonder if a brace from a Tudor Sedan would work? It seems to me that the contour of the rear center panel is similar between the two body styles.
By the way, ditto to "Snhcro909's" comment about extra weight on the spare tire carrier. As it is, you can flex the spare tire up and down in the rear and see the center panel tweaking. One spare tire ONLY unless additional bracing is added inside the body! Marshall Last edited by Marshall V. Daut; 10-20-2024 at 05:22 PM. |
If it was mine I would put a trunk back there. A lot more practical than another spare.
Charlie Stephens |
A left fender and a rear spare seems unbalanced. I’d consider a right fender spare before a rear if you really want a second spare. Not that you asked…
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#10 | |
![]() Quote:
I just checked the spare tire re-inforcing bracket in my 1928 Phaeton. Unfortunately my spare brackets are all too short. It takes a really long one, probably the same as a Tudor Sedan's bracket. I suspect mine are from Coupes and Roadsters with their short rear lower panel (below the decklid), while the Phaeton and Tudor Sedan have that large center panel that needs the extra length and strength of a longer re-inforcing bracket so that the panel doesn't stretch from the weight of the wheel and tire, let alone the carrier itself.
'Sorry... ![]() Marshall |
The inner channel support ‘29 Touring. I believe spare tire mount same part # as Tudor model.
#13 |
Very similar to the 31 Tudor
