Old 08-26-2024, 02:12 PM   #1
markdtn
markdtn's Avatar
Default Try a new offshore Holley 94-are they that bad?
I have a '44 2N tractor with a '50 8BA V8. Built in '17. Bone stock rebuild with .030 over pistons and stock truck cam. Stock Loadmatic distributor. Timed at 2 degrees (pin to line) with hardline to distributor capped. The carb was in bad shape when I got it. I have gone through it a few times but it really isn't right. It runs and idles but has always been rich. I am considering a new China 94 but with adding a genuine Holley power valve and jets. My application is a bit unique in that I don't really change throttle setting continuously like a car. I almost don't need an accelerator pump.
So how bad could that be for my application? I don't really want a China carb but I need it running at it's best next Friday. Thoughts?
markdtn is offline   Reply With Quote
Old 08-26-2024, 03:18 PM   #2
rockfla
rockfla's Avatar
Default Re: Try a new offshore Holley 94-are they that bad?
IMO
Send the one you have to Charlie Schwindler (CharlieNY) and let him rebuild it. IT will be 100% when you get it back, test run and basically a plug and play!!!! You will not be disappointed
Charlie Schwindler
5845 Cole Road
Orchard Park NY 14127
Old 08-26-2024, 03:19 PM   #3
flatjack9
flatjack9's Avatar
Why have you capped the distributor line. Won't get any advance without it. Won't run well.
Old 08-26-2024, 04:27 PM   #4
GB SISSON
GB SISSON's Avatar
I get that your tractor event is on Friday so I'll be the guy that says I have a chinacarb on my techemsah log splitter, (13.00), my son's honda dirtbike (18.00), my '79 toyota landcfruiser (67.00) and have one on the way for my stihl pressure washer (18.00). They all start nicely and perform the work they were intended to do. Last time I checked the Chinese were doing a pretty good job with the I phones, so I think to answer your question, these carbs aren't all that bad. I like running the holleys on my flatheads, but I have more of them sitting around than I have engines. In closing, I am sure a Charley NY carb is a way better piece and when the time constraint is over, send your 94 out to Charley and have a proper jewel on your manifold.
Old 08-26-2024, 07:03 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
He is exactly right . . . it will run a lot better/stronger with more spark advance.
Old 08-26-2024, 10:07 PM   #6
52flthed
Well they look identical under an oil bath air cleaner to the originals except the ford script. They aren’t cheap either! I gave up on rebuilding originals a few years ago after the same local legend rebuilt it twice and it ran worse each time it came back. I have one on my truck and it runs flawlessly. Eventually I’ll get around to trying to find someone who can rebuild a decent original one. But some of them might be beyond rebuilding. Not sure if that’s the case but I’ve been told.,
52flthed is offline   Reply With Quote
Old 08-26-2024, 10:09 PM   #7
19Fordy
19Fordy's Avatar
Avoid using a China made carb if at all possible.
Old 08-27-2024, 06:13 AM   #8
markdtn
markdtn's Avatar
I only capped it to set the timing. Sorry, I should have been clearer.
I thought Charlie was not taking any new work and his wife was very sick?
I have procrastinated on this so it's my fault. There is a tractor show next weekend that has an optional 10 mile drive associated with it that I have always wanted to go on but was afraid. I should have started on this repair a month or so ago. I may try it, you can get one for $108 on evilbay.
Thanks!
Old 08-27-2024, 07:14 AM   #9
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Charlie’s wife passed, bless her soul. He is back to work.
Tim Carlig
dean333 is offline   Reply With Quote
Old 08-27-2024, 07:46 AM   #10
rockfla
rockfla's Avatar
Thanks!
As Tim stated above, I talked with Charlie last week, he is back in the shop....maybe a few days longer as he does have a back log of work BUT thankfully, he is back at his craft!!!!! I sent him two Detroit lubricators as a matter of fact
Old 08-27-2024, 03:24 PM   #11
40 Deluxe
Wasn't it to set the timing? As I remember, that is book procedure.
Old 08-27-2024, 05:35 PM   #12
GB SISSON
GB SISSON's Avatar
That's a very cool tractor Mark!
Old 08-27-2024, 06:13 PM   #13
cadillac512
cadillac512's Avatar
Looks like you're about 75 miles from McMinnville. Maybe Michael at Third Gen can help you?
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-27-2024, 06:45 PM   #14
Graeme / New Zealand
Graeme / New Zealand's Avatar
That Tractor is a beaut. The V8 truck badge on the front of the hood is a nice touch.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 08-28-2024, 06:25 AM   #15
markdtn
markdtn's Avatar
GB
Thank you. I wanted it to be as "period correct" as possible. But I did not want headlights so the V8 badges cover the holes in the doglegs for the headlights. That photo is my favorite of it. Since then I added mufflers and a grille guard.
Just in case anyone is unfamiliar, Funk Aircraft Company built a kit from 1948-1952 to put a flathead 6 or an 8BA in a 8N tractor (it also works on a 9N or 2N but with modifications). Farmers wanted more power for pulley work or larger plows. There were about 200 V8 and 6000 6 Funk kits made. Mine is not one of those. It is a kit from Awesome Henry. Pretty easy to install. My biggest issue is cooling. I went through several iterations of radiator until now I have an aluminum radiator with electric fan-so much for period correct-and it does OK. I am always mindful of having 100HP with a 24HP transmission.
I ordered an offshore carb from Ebay and a genuine Holley 94 power valve and a set of 51 jets. I'll update with my results.
Old 09-05-2024, 04:49 PM   #16
jimmy_paycheck
jimmy_paycheck's Avatar
I just asked them about carbs, and they no longer do rebuilds.
jimmy_paycheck is offline   Reply With Quote
Old 09-06-2024, 07:36 AM   #17
corvette8n
corvette8n's Avatar
Welcome to the barn, I sold my 8n a few years ago now I’m sorry I did.
https://www.fordbarn.com/forum/pictu...ictureid=28453
Old 09-09-2024, 07:51 AM   #18
markdtn
markdtn's Avatar
Just an update. Bought an offshore 94 on Ebay from JDM Speed. $118 delivered. Bought a set of genuine Holley #51 jets and a genuine Holley 4.5 Power Valve. Took the new carb apart and the float height was very close. Swapped the jets and power valve and put it back together. Bolted right on with no issue. The ball for the throttle linkage was too big for my worn out coupler but a few touches with a die grinder and they went together fine. The vacuum port for the distributor was fine. It had parts for what I assume is a kickdown on the left side but I did not need that. Changed from their choke cable bracket to my original but if I had an uncut choke cable theirs would have been fine. The fuel inlet fitting provided was for 3/8 hose and I had 5/16 but it was OK. I started with the idle screws out 1 1/2 turns and after setting the idle and letting it warm up I ended up about 3/4 of a turn out. (the carb that was on there would still run with idle screws all the way in) It starts quickly, idles nice, and no backfiring anymore. I went on a tractor ride that was 8 miles out and probably more like 10 back on the more scenic route. I have a Caterpillar temperature gauge with no numbers but it was not right on the red zone which is a change-it's always been in the red even on a cool day after a mile of running. I know the carb is not always the problem but it really worked well for me. Obviously 18 miles is nothing in a car but a long way at road speed on a tractor with a V8 and 4-cyl sized radiator (but it is aluminum with an electric fan). Next year I would like to find a Sherman transmission with overdrive to slow the RPMs at road speed. Anyway, the new offshore 94 carb worked well for me.
Old 09-09-2024, 08:21 AM   #19
tubman
tubman's Avatar
I'm glad that somebody decided to "take the plunge". Thank you for taking the time to do this and reporting back. It is good to have another source of workable components
