Old 07-20-2024, 11:31 AM   #1
ronzmtrwrx
Default Removing female dovetail assembly on 39 Conv
As the title states, I need to remove the dovetail assemblies in the b pillar on my 39 Conv. I know I’ll have to drill the rivets out, but I don’t see a way to get it out of the b pillar once it’s loose. The b pillar is totally enclosed on all sides.
ronzmtrwrx is offline   Reply With Quote
Old 07-20-2024, 11:45 AM   #2
Kube
Kube's Avatar
Default Re: Removing female dovetail assembly on 39 Conv
You'll need to drill the rivets out, cut an opening in the rear of the B pillar to remove the assembly.
Why do you want to remove the assembly?
Old 07-20-2024, 11:49 AM   #3
ronzmtrwrx
They are worn out.
Old 07-20-2024, 11:49 AM   #4
ronzmtrwrx
Will the guts come out without removing the whole assembly?
Old 07-20-2024, 12:00 PM   #5
ronzmtrwrx
Hahaa. Never mind. I see how the innards come out now. I still need to tig up the lower edge of the opening and straighten that up, but I should be able to do that with the housing still in place.
Old 07-20-2024, 12:00 PM   #6
ronzmtrwrx
Thanks for the reply Kube.
Old 07-20-2024, 03:33 PM   #7
Kube
Kube's Avatar
Glad you have this sorted. That bottom edge is often worn when the strikers were allowed to wear well beyond their useful life. I have welded up many
