Old 07-11-2024, 05:19 PM   #1
blownford
Default '36 Coupe top of door seal
I was ordering the seal that installed on the top of the doors 48-702 0532. On my car they are installed on the door, sure look like they belong there. On Dennis Carpenters site it says they are installed on the body.
They go on the door, right?
blownford is offline   Reply With Quote
Old 07-11-2024, 07:02 PM   #2
fordyford
fordyford's Avatar
Default Re: '36 Coupe top of door seal
1935/36 cars have a steel channel on the door to hold the rubber seal. 1937/48 the rubber seal glued to the body.
fordyford is offline   Reply With Quote
Old 07-11-2024, 09:17 PM   #3
rich b
rich b's Avatar
Be sure to clean out every bit of the old seal.
Lube up the new seal along with the channel, grab the end with a vice grip, and pull it in all at once without stopping.
If it gets stuck, stop, work it back out, double check the channel, lube it again, and give it another try.
Old 07-11-2024, 09:31 PM   #4
ssffnomad
ssffnomad's Avatar
Good info guys .
Sounds like fun.
Cant wait.
Long ways off on 36’ 3W project.
THANKS
ssffnomad is offline   Reply With Quote
Old 07-11-2024, 11:32 PM   #5
Rockymountainsparky
What would be the best lube? Dish soap?
Rockymountainsparky is offline   Reply With Quote
Old 07-12-2024, 06:58 AM   #6
rich b
rich b's Avatar
I use WD-40, wipe when done and the rest is soon evaporated.
Dish soap seems to get "gummy" for me.
Glass cleaner is also popular choice; note
some glass cleaners are slipperier than others.
