Old 05-19-2024, 07:50 PM   #1
Technite73
Default Eaton gas cap, original or aftermarket?
I picked up an old gas cap. It was advertised as an Eaton.
There are no Eaton markings on the inside.
Did Eaton make them without adding their markings?
Technite73 is offline   Reply With Quote
Old 05-19-2024, 09:50 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Eaton gas cap, original or aftermarket?
Rusted away. Looks like they would have to pay royalties if it isn't.
Old 05-19-2024, 11:32 PM   #3
Hitman
The direct answer, which is helpful in future searches of the forum:
The picture shows an original Eaton gas cap. This is because of the vent holes and a side profile would show a height of about 1/2”.
Hitman is offline   Reply With Quote
Old 05-20-2024, 06:41 AM   #4
Model "A" Fords
Dissolve the rust (Evaporust) and you may be able to see some traces of the printing with a magnifying glass. This view looks like an Eaton cap. A side view would help.
Model "A" Fords is offline   Reply With Quote
Old 05-20-2024, 10:56 AM   #5
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
My cap is rustier than this one
Is it better to use Evaporust and clean it up?
Or buy a new reproduction cap?
fried okra is offline   Reply With Quote
Old 05-20-2024, 11:50 AM   #6
JayJay
Okra - I have not had good luck with repro 30/31 caps, they've either been too tight to rotate to seal (had to bend the tabs on the cap) or too loose to seal properly (had to fiddle with gaskets). As with most things, if you can find a good original, perhaps needing a bit of cosmetic work, much better than going repro.
Evaporust, followed by some pickin' to make sure the vent holes are open, would be my suggestion. BTW, Evaporust says that you can immerse for minutes to hours, I have not found that effective, I go overnight on almost all things.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 05-20-2024, 12:36 PM   #7
Technite73
I have soaked it in Evaporust. It removed all the rust but there is no trace of any markings.
Old 05-20-2024, 01:46 PM   #8
Two-Gun Bob
Can these caps be disassembled to work out dents in the top and then re-assembled?
Two-Gun Bob is offline   Reply With Quote
