Old 02-15-2024, 03:02 PM   #1
19Fordy
19Fordy's Avatar
Default Update on 1928-48 Universal Joint kit installation
Thanks to suggestions offered in my original post I was able to assemble the U-Joint using rebuild kit.
Sadly, I cracked one of the bearing bushings that fit into the yoke. I still finished the installation using that bushing. The bushing crack is almost imperceptible and is positioned at the bottom of the yoke opening as shown below.
Would it be ok to go ahead and use this U-joint as there is no direct load on the bushing/bearing? All is good except for the hairline crack.
Cost of rebuild kit plus shipping and tax was $82.39 so I would like to think I can still use the U-joint. I don't think I can buy a bushing separately. Thanks again, Jim
PS: To assemble, drop the cross bar (minus the bushings) into one of the yokes halves. Then gently tap on one bushing (with the inside chamfer facing inward (Photo 3) and tap it in just a little bit onto the crossbar and into the yoke. Don't tap it all the way in. Then flip the yoke over and you will find that you can pretty much center the opposite crossbar so it's visually "centered" in the yoke opening Photo 2. Then, insert the other bushing (inside chamfer facing inward) onto the opposite crossbar and gently tap it into the same yoke - a little bit equal to the opposite side. Then move the yoke back and forth to help center it. Then, alternately tap each bushing inward just a little bit onto the cross bar. Go from side to side and don't hit the bushing fully inward all at once. Keep moving the yoke to see if it swivels and keep tapping the bushing in to the correct distance where the grooves for the safety wire line up. This tapping action on each bushing is done while holding the U-joint in one hand and tapping the bushing inward. Follow this procedure for the other yoke and crossbar. I applied WD-40 to make surfaces slippery.
Unfortunately, I cracked a bushing while trying to obtain the best crossbar/yoke/bearing fit so it would swivel properly. If anyone has an extra bearing, bushing please keep me in mind.
Old 02-15-2024, 03:05 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Update on 1928-48 Universal Joint kit installation
Old 02-15-2024, 04:05 PM   #3
19Fordy
19Fordy's Avatar
Thanks Pete. Your magnification really makes a huge difference.
Old 02-15-2024, 04:14 PM   #4
Seth Swoboda
Seth Swoboda's Avatar
Could you use one of the bearing bushings from the old U Joint? How does it fit?
Old 02-15-2024, 04:19 PM   #5
19Fordy
19Fordy's Avatar
No, old U-Joint bushings are "sloppy" fit. Worn out.
Wish I new who is actually making this kit so I could request a new bushing.
Old 02-15-2024, 05:58 PM   #6
ursus
Also of interest would be a source for the circular spring clips. They are an odd size which is hard to approximate using the common SAE or metric sizes. When being pushed into position they are under a lot of tension and will take flight to parts unknown if they get away from you. Happened to me once or twice, so remember to wear eye protection!
ursus is online now   Reply With Quote
Old 02-15-2024, 06:02 PM   #7
Seth Swoboda
There is a guy in the swap section selling what he describes as a really good U Joint for $60. You might inquire.
I had an issue with a rebuild kit where the bushings extended out past the yoke further than the original. I carefully removed some material just to be sure it did not interfere with the inner clam shell.
Old 02-16-2024, 05:51 AM   #8
Mac VP
Mac VP's Avatar
The replacement bushings don’t have the snap ring groove in the exact middle of the bushing. It’s important to install them as they come in the package. If you mix up the orientation of the groove, you’ll have the bushing sticking out past the yoke when done and that can potentially hit the inner cap of the clamshell.
We have sets of the original bushings(NOS) that we sell. I can’t sell an individual bushing out of the set, so hopefully someone can help you with the single bushing.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 02-16-2024, 10:02 AM   #9
pistonbroke
Mac, On that note what is the best way or tool for removing the C clips? I just did a conversion from truck 4 speed to the 39 style three speed that involved changing the front yoke to the smaller spline. Those clips were a pain. Tim
Old 02-16-2024, 10:52 AM   #10
cadillac512
cadillac512's Avatar
If that cracked bushing were mine, I'd run it in the position it sits. But unlike others, I don't mind pushing my luck a bit if the physics makes sense to me.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 02-16-2024, 12:52 PM   #11
ursus
The C-clips are made of spring steel which explains why it is difficult to coax them out of the grooves. The trick is to give the clips a hard smack with a dull chisel. This helps to relieve the spring tension and deforms the clip into a slightly open position which makes them easier to remove.
Old 02-16-2024, 01:05 PM   #12
Kube
Kube's Avatar
I'd replace that bushing. Why? Gosh, the amount / time of work it requires to access that assembly, well, I wouldn't take a chance at having to do it again.
Old 02-16-2024, 06:29 PM   #13
19Fordy
19Fordy's Avatar
I used a Dremel tool with a small cut off wheel to slice through the clips. Then pried them up and pulled them out with a pair if side cutters.
Old 02-16-2024, 06:35 PM   #14
19Fordy
19Fordy's Avatar
Yes Mac. I too noticed that snap ring groove offset. Unfortunately, the installation instruction do not even mention it.
