am looking for a 1940<s big truck air compressor that that went on the pto or information they were mostly on military trucks .most people don't know that existed . also pto leaver for my 47 coe 811z7269 1938/47 thanks todd murthum
Worthington compressor is what i have seen but the ones i looked at had a split driveline like a firetruck to get the RPMS faster then a PTO.
Im sure they are all gone now, but i seen a few in a junkyard north of baltimore and the trucks were old baltimore gas trucks. |
I believe the compressors were belt drive on those trucks.
Bruce
Works good Lasts long time |
i have a trans with a pto on it if you are in need
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP ![]() Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand ![]() https://www.fordbarn.com/forum/album.php?albumid=580 |
Hi Meric42,
Would you have any additional information on the tire pump? Mine looks very similar and I am looking for a set of rings for it. Appreciate if you have any more information or know where I may find some. Cheers Corey Sent from my SM-F936B using Tapatalk |
Just for fun, did you know there are at least three different air compressors for Ford trucks? One is mounted on the side of the transmission for small jobs like inflating a tire, another on the front of the engine was used to provide compressed air for a pneumatic brake booster system and yet another is a PTO driven air compressor for higher air demands.
Ford of Canada provided the transmission mounted air compressor for many trucks built during WW2. The air compressor (Westinghouse, Bendix and others) used for pneumatic brake booster systems came with all the other brake control parts. The PTO drive version is aftermarket equipment and came in many shapes and sizes.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
#9 | |
![]() Quote:
#10 | |
![]() Quote:
#11 | |
![]() Quote:
I found some rings online, oil ring fits perfect but the top ring is 1mm to narrow. As an interim measure only I have 2 oil rings fitted as the are the correct width. I will source the correct width compression ring. Cheers Corey Sent from my SM-F936B using Tapatalk |
My Blitz (CMP) parts book shows 2 PTO tyre pumps-
the Outboard Marine/Saylor Beall which is the one in Merics pic and the Webster pump which has a removable head. Manuel in Oz |
#13 |
Manuel, are there any diagrams in your parts book showing what these tire pumps look like? If so, can you post the images?
#14 | |
![]() Quote:
I had to get my daughter to help with the scanning. They are all exploded diagrams. I hope they come out ok. I can't see the scans so I don't know what order they are in. The Webster and the Outboard Marine are from the Blitz book and the Lorry one is from the Australian Army book. Manuel in Oz Last edited by Manuel; 01-18-2024 at 04:53 AM. Reason: One scan came thru twice. |
#15 |
The four scanned pages came out just fine. Thanks for posting.
Sure do like the illustrations Ford of Canada included in many of their parts catalogues!
#16 | |
![]() Quote:
#17 |
If you are still looking, the old Ford piston ring part number is C11Q19925.
