#20 |
It could be the square bolt at the top of the springs is not seated in the crossmember slot. To check this, loosen the nuts on the u-bolts holding the spring set. Grab hold of the bumper on the low side and lift the car in a rocking motion. You will hear and see if the square bolt seats in its spot on the crossmember.
