Old 10-06-2023, 06:53 PM   #21
JOES31
JOES31's Avatar
Default Re: Fuel Filter issue
The Wix filter is good and I use that with what I said before. No need to overthink
this.
JOES31 is offline   Reply With Quote
Old 10-06-2023, 09:42 PM   #22
henry's 31
I use the John Deere GY20709. You can get it at any box store. It is for a garden tractor. Works well.
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 10-07-2023, 01:03 AM   #23
RandyinUtah
I have been using the gas filter for three VW bug for over 30 years with no problems. I have this filter under the dash on the line from the shutoff valve to the firewall. I don't care for having the filter in the engine compartment.
RandyinUtah is offline   Reply With Quote
Old 10-07-2023, 04:58 AM   #24
CarlG
CarlG's Avatar
Originally Posted by [email protected] View Post
Regarding the image Carl G posted.
Where is that available? Part number?
SA3-00
https://www.stevesaircraft.com/gascolator.php
Should be available at most Aircraft parts houses or Pilot Shops.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-07-2023, 06:43 AM   #25
old31
Carl, that thing better work for that kind of money. Yikes!
Looks like it might make a good hot Latte.
old31 is offline   Reply With Quote
Old 10-07-2023, 07:00 AM   #26
ModelAArmy
Carl,
What type of filter goes in that housing. Thanks
Tom in Texas
1931 Coupe
ModelAArmy is offline   Reply With Quote
Old 10-07-2023, 07:59 PM   #27
CarlG
CarlG's Avatar
Originally Posted by ModelAArmy View Post
Carl,
The screen is 149 micron 216 stainless steel
Alaskan A's
Old 10-21-2023, 01:25 PM   #28
[email protected]
joe.manfre@me.com's Avatar
Originally Posted by SDJason View Post
Same here
The local Oreillyauto can not get the Wix 33030 filter. Does it cross to a specific vehicle fit? Perhaps there is a Fram number out there?
joe.manfre@me.com is offline   Reply With Quote
Old 10-21-2023, 02:20 PM   #29
Jerry in Shasta
Jerry in Shasta's Avatar
I use 1980s Chev. fuel filter. It has the same flared fitting as the valve under
the tank. It is so grossly over size it does not interfere with fuel flow.
( a little larger than a coke can)
JB
l tank
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 10-21-2023, 05:10 PM   #30
Gene F
Gene F's Avatar
I use the factory filters (firewall, and carb), with a pencil filter in the ball valve that exits the tank. Oh, and I do not use BP/Sohio fuels.
Old 10-21-2023, 08:56 PM   #31
GPierce
GPierce's Avatar
I have that on my gravity feed airplane.
http://www.stevesaircraft.com/gascolator.php
GPierce is offline   Reply With Quote
Old 10-22-2023, 06:11 AM   #32
Werner
Werner's Avatar
Originally Posted by Gene F View Post
... Oh, and I do not use BP/Sohio fuels.
Please, tell me what's BP/Sohio fuel?
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-22-2023, 06:47 AM   #33
8EL
8EL's Avatar
BP - British Petroleum
SOHIO - Standard Oil of Ohio
Both are petroleum refiners retailing fossil fuel in North America. Standard Oil was founded by John Rockefeller in America. At some point it became AMOCO, which was bought out by BP, which is an English outfit.
Standard Oil alos developed a process of Ammoxidation complex chemical process involving o2 enrichment of the fuel. Therefore referred to as SOHIO gas.....
8EL is offline   Reply With Quote
Old 10-22-2023, 07:44 AM   #34
petew
petew's Avatar
Yes , works fine no problems
petew is offline   Reply With Quote
Old 10-22-2023, 08:52 AM   #35
8EL
8EL's Avatar
To my Kamerad in Deutschland, here are a couple of papers on the Sohio Acrylonitrile Process:
https://www.acs.org/education/whatis...lonitrile.html
https://www.sciencedirect.com/topics...g/ammoxidation
Old 10-22-2023, 10:01 AM   #36
Werner
Werner's Avatar
8EL,
thank you very much for the detailed explanation. This is therefore not a type of fuel. And the above rejection is a political decision, I think.
Werner
Citroen 11 CV, 1947
Old 10-22-2023, 10:52 AM   #37
Ramman
Originally Posted by Y-Blockhead View Post
I use a WIX 33039 in my glass sediment bowl. https://www.oreillyauto.com/detail/c...ter/wix0/33039
Do you use the metal end as the inlet or the gasketed end?
Ramman is offline   Reply With Quote
Old 10-25-2023, 11:33 AM   #38
ModelAArmy
Model A
Do you put the pill magnet inside the filter on the bottom or do you put it outside the filter on the bottom. Thanks
Tom in Texas
1931 Coupe
Old 10-25-2023, 12:02 PM   #39
Ernie Vitucci
Ernie Vitucci's Avatar
Good Morning...Our Model A has a glass filter on the firewall. I put a big magnet from Ace Hardware into the glass bowl. I can see when I need to open the filter and clean the gunk off the magnet...Has worked well for 18 years. Had my first Model A in the early 60's and that is how it was rigged when I purchased it. I've just continued to do the same thing. Ernie in Arizona
Old 10-25-2023, 10:44 PM   #40
Y-Blockhead
Y-Blockhead's Avatar
It should be Wix 33039.
