Old 07-21-2023, 06:25 PM   #1
Vanspeed
Vanspeed's Avatar
Default Alternate bolt set for 1940 cab mounting?
Hi guys I know the bolt kit that was being made is now not available. What have you guys used as an alternative? I like the springs under the frame but I have no idea where you can find those springs.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 07-21-2023, 07:00 PM   #2
fordscript
fordscript's Avatar
Default Re: Alternate bolt set for 1940 cab mounting?
You can use coach bolts, shorten or re-thread as necessary. use valve springs and shorten them to suit. Hope this helps.
fordscript is offline   Reply With Quote
Old 07-21-2023, 08:55 PM   #3
Vanspeed
Vanspeed's Avatar
It does. When you refer to coach bolts is that the same as carriage bolts?
Old 07-22-2023, 07:34 AM   #4
Mart
Mart's Avatar
Yeah. Coach bolts = carriage bolts.
Old 07-22-2023, 08:19 AM   #5
Kube
Kube's Avatar
I'd suggest McMaster-Carr.
Springs? Die springs are available in a zillion different diameters and lengths.
I would advise against using carriage bolts as the heads would protrude from the bed floor. Instead, I'd use flat head bolts just as Ford did.
Also available in a zillion sizes and lengths.
McMaster is reasonably priced and ships the same day.
Old 07-22-2023, 11:21 AM   #6
Vanspeed
Vanspeed's Avatar
As far as the bed I used a Horkey wood conversion so I am set there. I was asking about the special bolts/springs that attach the cab to the frame.
Old 07-22-2023, 11:49 AM   #7
Kube
Kube's Avatar
I realize what springs you are seeking. My response remains the same... McMaster-Carr, die springs.
