Hi guys I know the bolt kit that was being made is now not available. What have you guys used as an alternative? I like the springs under the frame but I have no idea where you can find those springs.
Respecting and Resurrecting Ford Model A's. |
You can use coach bolts, shorten or re-thread as necessary. use valve springs and shorten them to suit. Hope this helps.
It does. When you refer to coach bolts is that the same as carriage bolts?
Yeah. Coach bolts = carriage bolts.
#5 | |
![]() Quote:
Springs? Die springs are available in a zillion different diameters and lengths. I would advise against using carriage bolts as the heads would protrude from the bed floor. Instead, I'd use flat head bolts just as Ford did. Also available in a zillion sizes and lengths. McMaster is reasonably priced and ships the same day.
#6 | |
I realize what springs you are seeking. My response remains the same... McMaster-Carr, die springs.
