Old 04-23-2023, 08:24 PM   #5
V8 Bob
V8 Bob's Avatar
Default Re: Converted 46 Ford heater to 12 volts
Originally Posted by dono50 View Post
Sounds good. How did you wire the toggle switch ?
I found a 30 amp toggle switch 3 position reverse polarity DC motor control on line. The part number is 28PR-MTD, if still available. Motor connects to the middle contacts, + and - 12V to one end.
I mounted the switch to the top of the heater housing, and wired so "up" is defrost and "down" is heat.
