Old 01-10-2023, 05:32 PM   #1
KJ714
Default Seperating 1936 flathead engine and transmission
Hi,
I'm going to remove a 1936 flathead engine from the car and seperate from the transmission. Is there anything special to do or be careful about concerning the throw out, clutch, or clutch basket ? Removing the engine for rebuild. I've done this in late model cars a few times but never an early V8 so just checking before I create a mini disaster, thanks.
KJ714 is offline   Reply With Quote
Old 01-10-2023, 06:34 PM   #2
Steve in Denver
Steve in Denver's Avatar
Default Re: Seperating 1936 flathead engine and transmission
I took mine out engine and trans at the same time. I removed the grill and used an engine hoist with one of those engine tilt things so I could almost stand the engine and trans straight. I rented a 1 1/2 ton hoist. I should have rented the 2 1/2 ton hoist. the 1 1/2 did not have enough length to easily reach the engine. Oh, and I removed the manifold and made a plate to bolt to the engine, then to attach the hoist to. I probably could have just bolted it to the block, but did not want to scratch or dent anything.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 01-10-2023, 07:11 PM   #3
Mart
Mart's Avatar
Separation of the engine and transmission is purely conventional. Nothing out of the ordinary.
Removal of the engine from the vehicle is subject to a lot more consideration, but I am not sure if you are asking about that. Engine steady rods for example will need to be detached.
Old 01-11-2023, 06:53 AM   #4
Mac VP
Mac VP's Avatar
There are two dowel pins in the engine block to help align the gearbox to the engine block. They can be a snug fit and you will have to carefully pry the two (engine and transmission) apart about a half inch. Depending on how long the engine and transmission have lived together, and how much of a damp environment they’ve endured, the input shaft of the trans could be stuck to the clutch disc…..which can resist separation.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 01-11-2023, 07:58 AM   #5
Mart
Mart's Avatar
Sometimes pressing on the clutch pedal can help push the engine away from the trans.
Old 01-11-2023, 03:23 PM   #6
KJ714
Awesome, thanks for the great tips everyone!
Old 01-11-2023, 08:58 PM   #7
47topless
47topless's Avatar
My vote is remove engine and tranny together. Makes installation much easier.
47topless is offline   Reply With Quote
Old 01-12-2023, 01:54 PM   #8
KJ714
I can do either way, the body is off the frame. I have a later model flattie that I want to hook up and run for a little bit while the 36 flathead is getting refurbished.
