Old 11-13-2022, 10:58 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Wiring harness question
Anyone have a recommendation for a wiring harness maker for a 31 coupe??
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 11-14-2022, 01:44 AM   #2
Brentwood Bob
Default Re: Wiring harness question
Sacramento Vintage.
https://www.vintageford.com/sect_main.cfm?Line=main
Brentwood Bob is offline   Reply With Quote
Old 11-14-2022, 03:19 AM   #3
verdirick
Try Bauer Electronics in Bend Oregon. They have built 2 harness for me. give them 10 stars.. Phone # (541) 389-7755 Rick
verdirick is offline   Reply With Quote
Old 11-14-2022, 04:40 AM   #4
mhsprecher
mhsprecher's Avatar
Tyree Harris is another good source. 805-556-5200. He is in Bumpass, VA.
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 11-14-2022, 06:57 AM   #5
Bruce of MN
Bruce of MN's Avatar
The harness for my '31 Coupe from Brattons was fine.
Old 11-14-2022, 08:39 AM   #6
51504bat
51504bat's Avatar
YnZ Yesterdays Parts
https://www.ynzyesterdaysparts.com/
They offer additional options such as turn signal add on wiring, or not depending on your needs.
Old 11-14-2022, 10:48 AM   #7
Rob Doe
I ordered from Tyree recently. Great service and a good part, too. I like supporting the little guy, the independent. My family survived on a small business income.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 11-14-2022, 05:30 PM   #8
brito36
Tyree Harris is the man to go to.
brito36 is offline   Reply With Quote
Old 11-14-2022, 07:14 PM   #9
rotorwrench
rotorwrench's Avatar
Bauer Electronics fabricates them for several different parts sources. They are decent quality and come with good instruction sheets. All model A harnesses are pretty much the same with exception to some AA trucks due to frame lengths and tail light distance from the light switch. Some have better light switch terminal discs than others. Rhode Island Wire likely makes up the best quality harness but they will likely be a bit more expensive too. They coat the fabric wire covering with a clear coat to keep the color longer Bauer doesn't coat theirs.
Old 11-15-2022, 12:07 AM   #10
old31
Bratton makes a very good harness, with all the connector ends being soldered, as opposed to Snyders that has clip on ends and no solder in the harness.
old31 is offline   Reply With Quote
Old 11-15-2022, 01:55 PM   #11
31Tudor
31Tudor's Avatar
For a show quality harness you cannot beat Tyree Harris. He has done two of them for me.
31Tudor is offline   Reply With Quote
Old 11-15-2022, 06:14 PM   #12
McMimmcs
McMimmcs's Avatar
The Bratton harness is exceptional!
Old 11-16-2022, 01:46 AM   #13
Brubaker
Brubaker's Avatar
I had an excellent experience with Tyree Harris (also) and was happy I gave him a call. He also custom-made a length I was missing as well.
Brubaker is offline   Reply With Quote
