Old 11-06-2022, 07:42 AM   #1
deuce lover
deuce lover's Avatar
Default '32 gas gauge I just restored
Some of you know that I do these.This is a rare French '32 Ford gas gauge (P instead of F on the face) I finished this morning.The line was plugged so bad that neither acetone or brake clean would free it up.Had to use diluted Chloric acid.Before and after pics.
Old 11-06-2022, 08:03 AM   #2
sugarmaker
sugarmaker's Avatar
Default Re: '32 gas gauge I just restored
deuce lover,
Wow does that look nice. How do you clean inside?
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
1966 Ford F100
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 11-06-2022, 08:13 AM   #3
deuce lover
Chris,I carefully take it all apart ,bead blast the case or wire wheel depending how rusty(some don't need it),clean the line using paint spray gun brushes from HF and acetone or acid,clean the lens,make new gaskets,make a new white paper backing,0000 steel wool to clean the chrome then reassemble.Thread chaser on the threads.Small blow gun tip w/compressed air w/pressure turned down is necessary also.
Old 11-06-2022, 08:17 AM   #4
highbeams
highbeams's Avatar
WoW! Colossal gauge now!
I have a '33 that hasn't been touched in 87 yrs, assembly line. Like the rest of the car.(other'n one repaint.)
highbeams is offline   Reply With Quote
Old 11-06-2022, 08:20 AM   #5
deuce lover
Highbeams,Here is a '33-34 I did a couple months ago.
Old 11-06-2022, 09:07 AM   #6
deuce5wndw
deuce5wndw's Avatar
You do great work!
deuce5wndw is offline   Reply With Quote
Old 11-06-2022, 09:15 AM   #7
deuce lover
Thank you !!
Old 11-06-2022, 09:47 AM   #8
deuce_roadster
deuce_roadster's Avatar
Nice job. I also have done a bunch of 32-34s for the swap meets and it is satisfying to bring back a scuzzy looking mess to like new condition. You can tell if it is going to work by rapidly tapping your finger on the inlet tube and seeing liquid move up the glass. One of the vendors sells the gaskets that go in by the lenses (or maybe they used to).
Old 11-06-2022, 10:45 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by deuce lover View Post
Some of you know that I do these. This is a rare French '32 Ford gas gauge (P instead of F on the face) I finished this morning. Before and after pics.
Sheldon.... Nothing short of what WE would expect, from those of us who know how you do things.... downright gorgeous!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 11-06-2022, 10:53 AM   #10
deuce lover
Thanks Coop !!
Old 11-06-2022, 05:46 PM   #11
al's28/33
al's28/33's Avatar
Excellent work, very clean and authentic. Only if these gauges were a bit more friendly to restore I would love to have mine work properly. I substituted a later year needle gauge and it has been loyally assisting almost 20 years.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 11-07-2022, 06:36 AM   #12
glennpm
glennpm's Avatar
Great restorations!
Glenn
Old 11-07-2022, 06:43 AM   #13
Bored&Stroked
Bored&Stroked's Avatar
Really nice job - exceptional work! Thanks for sharing.
Old 11-07-2022, 10:53 PM   #14
Karl
Karl's Avatar
Sheldon -I presume the french word for full begins with P? Great work !!
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 11-08-2022, 12:43 AM   #15
V8COOPMAN
V8COOPMAN's Avatar
That "P" stands for "Plein"! Sheldon's probably still snoozin'!
Coop
T5 W/TORQUE TUBE
Old 11-08-2022, 12:57 AM   #16
deuce lover
Just woke up.Yes P for "plein".I should have mentioned that in first post.Sorry.
Now searching for the Spanish,German,Dutch etc versions
Old 11-08-2022, 03:52 PM   #17
Karl
Karl's Avatar
Are yes I remember now -I once saw an Australian woman on a french flight who when offered more food responded with "Je suis plein" ( I am full) which is a phrase in slang french that means I'm pregnant !!
Old 11-09-2022, 10:42 AM   #18
fortyfords
fortyfords's Avatar
I'm really impressed with your work
fortyfords is offline   Reply With Quote
Old 11-09-2022, 10:45 AM   #19
deuce lover
Thank you!
