06-21-2022, 05:53 AM | #1 |
1932 Ford rear brake drum questions
Is anyone reproducing the stock 32 Ford rear brake drums? I believe 32-34 are all the same. Can any other later years be used? If not, is there a source for a good used one?
06-21-2022, 07:26 AM | #2 |
Re: 1932 Ford rear brake drum questions
'32-34 brake drums have not been reproduced to the best of my knowledge and they are becoming a challenge to find still within usable inside diameter.
06-21-2022, 08:58 AM | #3 |
Good used ones are here on the 'Barn'. I can't give them away. Changeovers they are to hyd. Newc
06-21-2022, 08:35 PM | #4 |
06-21-2022, 08:39 PM | #5 |
06-21-2022, 10:35 PM | #6 |
06-21-2022, 11:25 PM | #7 |
06-22-2022, 04:48 AM | #8 |
06-22-2022, 07:44 PM | #9 | |
Ok gotcha. For what it is worth I searched the Fordbarn classifieds first, before posting, and I did not see any for sale. Perhaps I didn't search correctly. Anyway, I had a local gentleman reach out to me and I will see what he has this weekend. |
06-23-2022, 07:33 AM | #10 |
Who needs brakes? They are overrated. Never lift.....
06-23-2022, 05:19 PM | #11 |
Being that .060 is generally the max oversize when turning drums and .090 is usually the max wear throw away number; what would be considered a limit for purchase of a worn drum that didn't need turning and would be used on limited use car.
Seems most all '32-'34 & '35 drums I come across are pretty well used and I just hate to just scrap them. Makes you wonder what spec's they used in the old days since it is not uncommon to find shims behind brake linings. |
06-23-2022, 06:45 PM | #12 | |
I believe someone mentioned about a service that will reline brake drums back to spec. I'd assume this is not a cheap endeavor. |
06-23-2022, 10:43 PM | #13 |
How about sayings regarding the Ford juice brake drums with the bevel on the edge; if there was a flat edge left, they were good and if knife edged, they were all used up.
06-24-2022, 12:31 AM | #14 |
I like that theory Rich !
06-24-2022, 01:36 PM | #15 |
Use J&G Brake Drum Relining & Refurbishing www.jgrelining.com/ they will reline & refurbished your original brake drums and also re-arc your brake shoes to the drum.
