1932 Ford rear brake drum questions Is anyone reproducing the stock 32 Ford rear brake drums? I believe 32-34 are all the same. Can any other later years be used? If not, is there a source for a good used one?
Re: 1932 Ford rear brake drum questions '32-34 brake drums have not been reproduced to the best of my knowledge and they are becoming a challenge to find still within usable inside diameter.
Re: 1932 Ford rear brake drum questions Good used ones are here on the 'Barn'. I can't give them away. Changeovers they are to hyd. Newc
Re: 1932 Ford rear brake drum questions Quote:
I have a brake drum gauge what is the usable diameter for them? |
I didn't ask anyone to "give them away" so not sure what you are talking about. |
Re: 1932 Ford rear brake drum questions As in 'No one wants them'. Clean cast iron is now about $150 a ton locally. No responce to my adds. Newc
.060 max oversize. |
Thank you |
Ok gotcha. For what it is worth I searched the Fordbarn classifieds first, before posting, and I did not see any for sale. Perhaps I didn't search correctly. Anyway, I had a local gentleman reach out to me and I will see what he has this weekend. |
Re: 1932 Ford rear brake drum questions Who needs brakes? They are overrated. Never lift.....
Re: 1932 Ford rear brake drum questions Being that .060 is generally the max oversize when turning drums and .090 is usually the max wear throw away number; what would be considered a limit for purchase of a worn drum that didn't need turning and would be used on limited use car.
Seems most all '32-'34 & '35 drums I come across are pretty well used and I just hate to just scrap them. Makes you wonder what spec's they used in the old days since it is not uncommon to find shims behind brake linings. |
I believe someone mentioned about a service that will reline brake drums back to spec. I'd assume this is not a cheap endeavor. |
Re: 1932 Ford rear brake drum questions How about sayings regarding the Ford juice brake drums with the bevel on the edge; if there was a flat edge left, they were good and if knife edged, they were all used up.
Re: 1932 Ford rear brake drum questions I like that theory Rich !
Re: 1932 Ford rear brake drum questions Use J&G Brake Drum Relining & Refurbishing www.jgrelining.com/ they will reline & refurbished your original brake drums and also re-arc your brake shoes to the drum.
