Old 04-01-2022, 08:08 PM   #1
david.skinner
david.skinner's Avatar
Default Points/Distributor repair NZ?
I regard myself as a reasonable competent mechanic but not yesterday. I installed a distributor 180 degrees out on the cam slot. I now have one failed distributor that I would like to know if it is likely repairable and if so can anyone in NZ do this or is it a trip for it to the USA and if so to whom?
Luckily I have a spare and had the sense to fit that one the right way around.
Regards
Dave Skinner
david.skinner is offline   Reply With Quote
Old 04-01-2022, 08:14 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Points/Distributor repair NZ?
>>> I now have one failed distributor>>>
What got busted on it?
Old 04-01-2022, 08:54 PM   #3
david.skinner
not sure Jack - but the points don't open when I turn it.
D>
Old 04-01-2022, 10:07 PM   #4
Phil Gillespie
Phil Gillespie's Avatar
Regards
Dave Skinner
They can be serviced in NZ.
To mind is Flathead Ted on this forum in Auckland.
Also down south is a guy in Ashburton who i have used and happy with.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 04-01-2022, 11:33 PM   #5
koates
You have not stated what vehicle and what distributor but I guess it is the divers helmet type. I have repaired several over the years that have the drive tang damaged by trying to fit them incorrectly. One even had a broken housing because it would mount up squarely to the timing gear cover. As an engineer you should be able to have a close inspection of the shaft, housing etc to see what is going on with it. Post some close up photos of it. Regards, Kevin.
koates is offline   Reply With Quote
Old 04-02-2022, 02:00 AM   #6
Brian
Brian's Avatar
David, I'm in Masterton, we've communicated before but never met. I have all the stuff to repair/set up your distributor. 021 242 6240
Old 04-02-2022, 03:25 PM   #7
david.skinner
Thanks so much Brian and everyone else. I'll give you call later today. To fill in the gaps the engine is an 81A and has a crab distributor. I notice that it has about 1mm of axial slop in the rotor. I wonder if this is enough of it to disengage from the cam slot resulting in me seeing no electrical pulses on the coil primary?
Regards
David
Old 04-02-2022, 03:48 PM   #8
Jack E/NJ
Jack E/NJ's Avatar
>>>I now have one failed distributor>>>>>> I notice that it has about 1mm of axial slop in the rotor.>>>
I think something else is causing no pulse.
Old 04-02-2022, 04:00 PM   #9
cas3
Brian will have you up and running in no time.
Old 04-02-2022, 04:50 PM   #10
VeryTangled
VeryTangled's Avatar
Thanks so much Brian and everyone else. I'll give you call later today...Regards David
Ain't the FordBarn great? Worldwide tech support at your keyboard.
-Jeff H
Old 04-02-2022, 05:43 PM   #11
fordv8j
fordv8j's Avatar
I did that nothing usable but points, broke housing, bent everything
fordv8j is offline   Reply With Quote
