Old 02-18-2022, 01:11 AM   #1
Clem Clement
Clem Clement's Avatar
Default Transmission filling
Please remind me of a simple way to add tranny fluid without removing the floorboards? I use STP and90weight now.
I'm hearing Lubriplate makes a near 600 weight oil?
Old 02-18-2022, 02:03 AM   #2
Synchro909
Synchro909's Avatar
Default Re: Transmission filling
I use a device rather like an overgrown bicycle pump. It has a bent tube to just enter the gearbox. I suck up the oil by pulling the handle and push it into the coghouse by pushing it. One or two pumps and it is full. There are electric ones available too but I suspect they are designed for thinner oil.
Old 02-18-2022, 02:26 AM   #3
CarlG
CarlG's Avatar
Mitchell Mfg. makes a Transmission Dipstick Kit.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-18-2022, 05:24 AM   #4
ndnchf
ndnchf's Avatar
I just changed my transmission oil yesterday. I used 600wt from one of the well known vendors. It comes in quart bottles with a spout. I just reached up from below and filled it easily. BTW, it had some unknown heavier oil in it. Using the correct 600wt oil, it shifts much more smoothly.
ndnchf is offline   Reply With Quote
Old 02-18-2022, 07:03 AM   #5
Bruce of MN
Bruce of MN's Avatar
Try this:
https://www.harborfreight.com/gear-o...ump-61746.html
" this gear oil pump is designed to fit most lube containers. The pump dispenses one fluid ounce of product with each press for easy measurement."
Old 02-18-2022, 08:19 AM   #6
Patrick L.
Patrick L.'s Avatar
As mentioned most qt bottles have a spout. The bottle will fit inside the frame rail. Just squirt until transmitter is full.
I prefer either 140 or 250 wgt oil. I think the Lubriplate numbers are 288 and 299, or something like that. It can be looked up easily.
Old 02-18-2022, 08:56 AM   #7
31Tudor
31Tudor's Avatar
I use a squeeze mustard bottle. Put the gear oil in that, I cut the tip open larger and then reach up from underneath, squeeze and fill no problem. Easier to maneuver around. to bad there wasn't a cover plate on the floor board to remove. LOL
31Tudor is offline   Reply With Quote
Old 02-18-2022, 09:50 AM   #8
Mulletwagon
Mulletwagon's Avatar
Previous owner of my 31 cut a square hole in the passenger side floorboard which was covered by a sheet steel cover. Simple matter to roll back the mat, pull the cover and fill from above. Suspect the mod came as a kit.
Mulletwagon is offline   Reply With Quote
Old 02-18-2022, 10:14 AM   #9
old ugly
old ugly's Avatar
rose gun / suction gun
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 02-18-2022, 10:26 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
Hi Clem! I did this to my Model "A" to make filling its transmission easier. I can get down on the floor to fill the transmission, but I may never be able to get up again. I imagine that you have a similar problem.
By the way, I am still playing with my O-gauge railroad!
File Type: jpg Floorboard Mod- Transmission Fill Access.jpg (77.1 KB, 149 views)
File Type: jpg 2016 Bobs O-Gauge Model Railroad 194kb.jpg (82.7 KB, 121 views)
Bob Bidonde
Old 02-18-2022, 10:49 AM   #11
Gary WA
Gary WA's Avatar
Easy-Just put a piece clear hose over spout and squeeze!I use same mixture!
www.whidbeymodelaclub.com
Old 02-18-2022, 11:03 AM   #12
burner31
burner31's Avatar
You know that access plate for your battery, I installed another one on the other side, now I just move the floor mat and I have a quick and easy way to check and fill the tranny.
Keith
Shawnee OK
'31 SW 160-B
Old 02-18-2022, 04:41 PM   #13
eagle
eagle's Avatar
Buy a bottle of Lucas Oil Stabilizer, it comes in a bottle with a spout. Push a tube on the spout and stick into the fill hole, squeeze in until it starts to run out around the tube. Lucas Oil Stabilizer makes wonderful tranny fluid. Shifting will be smoother'n a baby's bum!
Old 02-18-2022, 06:49 PM   #14
Ruth
Kind of like Bob Bidonde suggested in post #10?
Ruth
Old 02-18-2022, 08:08 PM   #15
wwirz
Same method I use. Quite easy. The hard part is getting under the car.
wwirz is offline   Reply With Quote
Old 02-19-2022, 06:56 AM   #16
Wick
Wick's Avatar
Clem, I use a Marine lower unit oil pump. Install it on the bottle, place hose in the transmission. Push down on the pump handle. Works great with no mess. Warm oil helps.
Wick is offline   Reply With Quote
Old 02-19-2022, 08:37 AM   #17
old31
Originally Posted by Bruce of MN View Post
Try this:
That's exactly what i use and it works well.
old31 is offline   Reply With Quote
Old 02-19-2022, 06:32 PM   #18
hep1966
I bought 600 oil from a vendor that sells it in a squeeze bottle with spout. Brattons.
hep1966 is offline   Reply With Quote
Old 02-20-2022, 02:15 PM   #19
shew01
shew01's Avatar
I use something like this. It’s handy to remove the old oil too when you want fresh oil.
https://www.harborfreight.com/oil-su...gun-95468.html
Old 02-20-2022, 11:16 PM   #20
jeepguy1948
Mitchell makes the kit with a fill tube AND a dipstick. It comes with the required floor plate and is just like the battery access. I have one and I would recommend it. I'm more than a little curious about using the Lucas Oil Stabilizer.
jeepguy1948 is offline   Reply With Quote
