Old 05-13-2011, 08:03 PM   #1
bobgreco
bobgreco's Avatar
Question Frame Welting Question
Does the frame welting go above or below the splash shields, or both? When I took the truck apart, one side had it both above and below the splash shield, and the other only had it below.
Thanks!
Bob
bobgreco is offline   Reply With Quote
Old 05-13-2011, 08:08 PM   #2
Milton
Milton's Avatar
Default Re: Frame Welting Question
Mine was below only and ended at rear of the running board panel, the mounts are on top so no need for lacing there.
Milton is offline   Reply With Quote
Old 05-13-2011, 09:09 PM   #3
ford1
this may have already been answered but here goes, webbing on top of frame, splash aprons on top of webbing, rubber pads on top of splash aprons, body blocks on top of rubber pads, then the body, webbing runs from the front ot the frame under front frnders to the back of the splash aprons, it helps to tack or glue the rubber pads to the body blocks, cut a slot from the side to the edge of the pad so you can slip more pads in to align the body with the doors that way you dont have to remove the body bolts to add or remove the pads, "wescot auto" site has a drawing where and how the body blocks go
ford1 is offline   Reply With Quote
Old 05-14-2011, 05:22 AM   #4
bobgreco
bobgreco's Avatar
Thank you. I thought that mine had too much as the welting rolls you buy have only enough for one piece on each side.
