Right side tie rod end the castle nut is lower than the cotter pin hole. Anyone else have this issue?
I assume you mean there aren’t enough threads to fit the nut and get a cotter pin in. I have seen some variation in the length of the stud on tie rod ends. You probably have one that’s too short, and/or the steering arm boss is a bit too thick. Exchange it for another? Maybe you can compare a few to select the one with the longest stud.
No there are to many threads. When tight the cotter pin is above the castle nut
#5 | |
![]() Quote:
It’s not unheard of to need to add a washer under a tie rod nut, but mostly on a spindle where someone doesn’t know how to taper-machine correctly……. Not a situation with stock stuff. |
If there is no difference between the nuts on same brand rod ends then the tapered stub part may have been for a different assembly at manufacture. This would show a difference in the threaded stub length. It should be no problem to washer it up. If the nuts are different then a person had to go looking for nuts.
In aerospace hardware, there are long thread bolts and short thread bolts and they have different castellated nuts for each on cotter pin applications. Long thread nuts have a taller profile. |
