Old 11-08-2021, 06:46 PM   #1
PeteVS
PeteVS's Avatar
Default Do mufflers work with the flow reversed?
I read a bit on three chambered mufflers and they talked about sounds bouncing back and canceling the others out. It was a bit too much for me to digest. So, if I install a muffler backwards, what will happen? Thanks!
Old 11-08-2021, 06:56 PM   #2
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: Do mufflers work with the flow reversed?
Don't run chambered mufflers backwards. That would be a flow nightmare.
You can run traditional glass pack mufflers backwards. The ones you can see
through. There is a slight flow difference from what I recall.....
1948F-1Pickup is offline   Reply With Quote
Old 11-08-2021, 07:50 PM   #3
Ol' Ron
Ol' Ron's Avatar
In JWL's book. He goes into detail on the effects of stock and modifies exhaust systems have on performance . One example: Dual exhaust has no effect on performance over stock. and there is more.
Gramps
Old 11-09-2021, 08:39 PM   #4
GB SISSON
GB SISSON's Avatar
Funny, it has been well documented what happens when you play a beatles record or a country music record backwards. Maybe someone will record a backwards muffler and we can all chime in.
GB SISSON is online now   Reply With Quote
Old 11-09-2021, 09:59 PM   #5
Karl
Karl's Avatar
Hmm " I buried Paul" actually "Cranberry Sauce " and "We **** you like Supermen " off Sgt Peppers . Paul (or Billy Shears if you believe I buried Paul) is on record as saying " its definitely there but we never put it there "
Spooky ?
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 11-10-2021, 11:18 AM   #6
deuce_roadster
deuce_roadster's Avatar
The person who built my avatar motor at sometime in the past found that Fenton cast headers made less HP then stock exhaust manifolds on the Dyno. Which points to the fact that flatheads have terrible breathing problems and most of what you do may or may not help. On my avatar engine he built nice equal length headers to fit the 32 frame and I really have no idea if they make any difference. Didn't Dyno it with different exhaust. The car is quite responsive though. I think his proprietary cam grinds have more to do with the performance then anything. He has the cam lobes ground at 114 degrees instead of 110. Flatheads don't like overlap.
I think there are pictures of the exhaust system in the album of 32 roadster pictures. Stainless steel tubing with Edelbrock Stainless mufflers.
Old 11-10-2021, 03:52 PM   #7
hotrodart
hotrodart's Avatar
When you try it let us know how it goes.......it will depend on the muffler design....most are proprietary technology, but some are not. Some are straight through with the baffles oriented toward the front to catch the flow/noise. Installed backwards they should make the exhaust sound louder since the baffles will have little/no effect. chambered mufflers will flow in reverse, but might be less efficient at higher RPMs.
hotrodart is offline   Reply With Quote
Old 11-11-2021, 08:31 AM   #8
Ford Freak
Most manufacture's have a spec. sheet for each style muffler they make, and most will tell you if it is 'reversable" or not. Should be able to find the info you need online.
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 11-17-2021, 01:02 AM   #9
Graeme / New Zealand
Graeme / New Zealand's Avatar
And if you visit the cemetery in Vienna, Austria and stop off at Beethoven's grave and hear one of his symphonies being played backwards, it's probably him decomposing.
Graeme
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 11-17-2021, 02:46 AM   #10
koates
Graeme
Yeah, right Graeme, good one. Regards, Kevin.
koates is offline   Reply With Quote
