Old 08-24-2021, 01:52 PM   #1
Tribalmonkey
Default Roadster Backfiring
I know this has been discussed a bunch of times. I’ve read through many of the related threads but have not found a solution.
I rewired my roadster including the ignition. I also installed new plugs (gapped). Now it backfires really bad when I let off the throttle and going downhill under load. It didn't do this before. What can I do to fix this? What should I check?
Tribalmonkey is offline   Reply With Quote
Old 08-24-2021, 02:23 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Roadster Backfiring
Does it backfire through the carb or the muffler?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-24-2021, 03:41 PM   #3
Tribalmonkey
Through the muffler.
Old 08-24-2021, 03:47 PM   #4
Big hammer
GAV adjusted to lean, intake leaking, carburetor float set to low
get a bigger hammer tap done
Old 08-24-2021, 03:51 PM   #5
ETAModel
I am new to the A, and got lots of advice on where to set the Gav. Also was trying to improve my mpg. When I closed the Gav too much she would backfire every time I got off the foot feed.
Sounds like you have the same problem. Try opening the Gav. And see what happens.
ETAModel is offline   Reply With Quote
Old 08-24-2021, 04:23 PM   #6
Tribalmonkey
Doesn’t that sound opposite? Doesn’t that make it even more rich?
Old 08-24-2021, 04:31 PM   #7
Tribalmonkey
Also, I don’t understand why that would be different now when all I have done was replace plugs and wiring.
Old 08-24-2021, 04:34 PM   #8
noboD
How old is the gas?
noboD is offline   Reply With Quote
Old 08-24-2021, 04:41 PM   #9
Tribalmonkey
Originally Posted by noboD View Post
How old is the gas?
About a week old.
Old 08-24-2021, 04:50 PM   #10
Tribalmonkey
The only logic I can see with this is that running too lean makes your engine run hotter. Maybe that create more opportunities for combustion in your muffler.
Old 08-24-2021, 05:06 PM   #11
jg61hawk
You go to this thread post #4 and you start there... Get a carb rebuild by BUllock and then you have solved 99% fuel problems...
https://www.fordbarn.com/forum/showt...hlight=bullock
I have a rebuilt Bullock carb, GAV (oh the mystery GAV) is turned out about 1/2 and NEVER touched. My car did all sorts of crap before I got a real carb rebuilt by this guy... GAV, and all the rest are BS after the carb is restored to new.... they were made to run....I can't say enough about the difference in starting and running since my carb by Bullock.
jg61hawk is offline   Reply With Quote
Old 08-24-2021, 05:13 PM   #12
Tribalmonkey
Not saying that a carb rebuild wouldn’t help… but it ran fine Sunday. I didn’t touch the carb and now it is backfiring really bad. I messed with the electrical. All associated ignition wiring and new plugs. I have gone back through the wiring but I didn’t see anything.
Old 08-24-2021, 05:37 PM   #13
Jacksonlll
Jacksonlll's Avatar
Make sure you don’t have an intake leak at manifold and carb flange. Make sure. Sometimes hard to find.
Old 08-24-2021, 07:14 PM   #14
Synchro909
Synchro909's Avatar
All the symptoms of a leak in the intake tract somewhere. Something that hasn't been mentioned is the rotor button. They are known to track to earth and you can't see where. Try a known good one. Also check you are not getting the infamous Model A no 3/4 cross fire.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 08-24-2021, 07:48 PM   #15
Tribalmonkey
So I just drove it with the GAV open almost an extra full turn and it didn't backfire. I'm trying to make logic from that. Why would running richer be better? Why would running leaner cause backfire.
Old 08-24-2021, 08:33 PM   #16
nkaminar
nkaminar's Avatar
Nothing you did to the electrical caused the problem. The two are unrelated. You need to clean out the carburetor.
Lean will cause the backfiring. A jet or passage that is partially blocked in the carburetor will cause it to be lean. Opening the GAV will compensate for the blocked jet or passage.
Old 08-24-2021, 08:42 PM   #17
nkaminar
nkaminar's Avatar
i think the backfiring when lean is because the combustion is not complete. Any combustion that does take place is hotter. So fuel and oxygen are pumped out into the exhaust system and ignite.
Old 08-25-2021, 02:47 AM   #18
johnbuckley
johnbuckley's Avatar
sorry wrong post.
Old 08-25-2021, 12:51 PM   #19
Ernie Vitucci
Ernie Vitucci's Avatar
Good Morning...You might also have a condenser that is starting to go bad. They do this when they are about done...Get a good one (more expensive) the really cheep ones are not any good...Ernie in Arizona
