#3 | ||
![]() Quote:
Things have definitely changed over the years. It used be be that dad used play sand from the lumber yard to blast paint & rust away in the back yard. Now, the shop I use begins with plastic media to remove the paint, and then follows with aluminum oxide to remove any rust. Yes, any commercial paint stripper such as the Aircraft brand or the Orange Citrus will remove paint. Then clean thoroughly with water and use Rust911 or Evaporust to remove the rust. Try not to use an abrasive wheel as it removes metal too. |
