did you pack the bearings with the proper grease--such as crc sta lube 3131?. just cleaned out a 29 rear axle some one pumped grease into the fitting on bottom of end of housing--all they did was fill up the housing NONE went to the bearing. If you packed the bearings with regular grease then repack with correct grease
