Old 07-18-2020, 11:31 AM   #1
shew01
shew01's Avatar
Default Hood Latch Bumper Replacements
I just noticed that one of my hood latch bumpers is dried out hard and crumbling. I found these replacements online.
https://www.brattons.com/hood-latch-bumpers-7645.html
I presume you have to drill out the old ones. How do you install the new ones?
Old 07-18-2020, 11:42 AM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Hood Latch Bumper Replacements
I drilled mine out and used small stainless bolts.
Tacoma Bob is offline   Reply With Quote
Old 07-18-2020, 12:26 PM   #3
shew01
shew01's Avatar
Do you recall where you found small stainless bolts to fit?
Old 07-18-2020, 11:46 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by shew01 View Post
I presume you have to drill out the old ones. How do you install the new one?
I use a C-clamp that we modified using a Tonka Rivet Tool as the foundation. If you have a Mill, you can fab one fairly easily. Otherwise, make a tubular rivet upsetting tool on a lathe. If none of those are an option, I guess you could use a small machine screw from one of the big box stores.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-18-2020, 12:28 PM   #5
shew01
shew01's Avatar
Sorry. I don’t have that kind of machinery. I’ll probably need to look for stainless bolts locally, but I have no clue where to look. The big box store bolts will likely rust.
Old 07-18-2020, 12:33 PM   #6
Ruth
Our local Ace Hardware has good S/S screws and nuts. Look for non-magnetic S/S, has less iron in it.
Ruth
Old 07-18-2020, 01:50 PM   #7
shew01
shew01's Avatar
Thanks. That gives me a place to start.
Old 07-18-2020, 01:27 PM   #8
1931 flamingo
1931 flamingo's Avatar
I did the same thing (small machine screws), also did the corner leathers, painted the heads black.
Paul in CT
Old 07-18-2020, 02:12 PM   #9
BRENT in 10-uh-C
Lowe's typically has Hillman line on Aisle 1 that will probably be ok to use. While I feel sure they will have stainless fasteners too, don't get overly excited about the need of using stainless. The majority of your car is not stainless, -and since you are not worried about it being authentic looking, just get whatever type of machine screws you can source locally.
BRENT in 10-uh-C
Old 07-18-2020, 08:57 PM   #10
shew01
shew01's Avatar
I’ll need to check what I can find locally. Thanks for the feedback.
Old 07-18-2020, 02:37 PM   #11
Bill Cilker
Bill Cilker's Avatar
I was missing one on my unrestored Victoria and I was able to work a bumper on to the original rivet by heating it and using a little grease.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is online now   Reply With Quote
Old 07-18-2020, 08:55 PM   #12
shew01
shew01's Avatar
Hmmm... That seems easy enough to try.
Old 07-18-2020, 05:34 PM   #13
Curtis in MA
I used pop rivets, but the head was to small. Maybe add a washer.
Curtis in MA is offline   Reply With Quote
Old 07-18-2020, 08:56 PM   #14
shew01
shew01's Avatar
That’s not a bad idea.
Old 07-18-2020, 10:43 PM   #15
mass A man
mass A man's Avatar
You can order the proper tubular rivets from Mcmaster-Carr Co.
mass A man is offline   Reply With Quote
Old 07-18-2020, 10:46 PM   #16
J Franklin
J Franklin's Avatar
It looks like the kit in the first post had rivets.
Old 07-19-2020, 06:51 AM   #17
shew01
shew01's Avatar
Did you use a separate special tool to replace your bumpers?
Old 07-19-2020, 11:19 AM   #18
swo4rd
swo4rd's Avatar
You got the correct set...rivets are preferable as they will not vibrate loose and fall out. Hillman makes an excellent too to press these rivets on. You will need to get fittings to fit into the bumper...I made mine by buying steel rod at the hardware store and cutting them to size with a dremmel tool cutt off disc...then super glued them to the base piece...It took about a couple of days to the the tools, an hour or so to set it up and five minutes to press them on...
Have fun
swo4rd is offline   Reply With Quote
