Hello! Welcome to another exciting video from Mart's Garage. It's time to clean up the 1932 Ford frame and slap some paint on it. We also need to check that Richard hasn't been slacking on the F1. Lastly I custom fit some bolts to bolt the front crossmember in.
You might see from the intro that things have moved on a bit. All will be covered in future episodes. Thanks for watching. Mart. https://youtu.be/jA0Gs7Gxsxw |
I was wondering if anyone had any thoughts on Richard's 8BA block. Is that amount of damage usual or out of the ordinary?
Mart. |
This is probably pointless to say.......if we only lived closer, I give him one....Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
Interesting bit of work from Mart! I am doing much the same with an earlier crossmember that had been installed by a previous owner using carriage bolts (coach bolts in UK?) that were modified in the same manner as shown by Mart.
I am curious about the grade of bolt recommended as replacement for the original rivets. The stuff I pulled from my frame appear to be only US Grade 2 metallurgy. is that sufficient? |
#5 | |
![]() Quote:
Unless I'm doing it wrong, looking up various spec sheets and conversion charts, metric grade 8.8 appears to be somewhere between grade 5 and grade 8, towards the grade 5 end. Mart. |
"I can't cry as long as I know the Lord has risen " |
The block is no doubt a freeze crack, is it cracked anywhere else ?
Speaking of pan rail cracks, did the 59 AB that you put in your pickup hold up alright?
![]() Mike |
