Old 07-11-2020, 01:19 PM   #1
ursus
Default Re: Mart's Update: 1932 Ford Sedan Project Pt3. Frame paint. Crossmember fit. Rich's
Interesting bit of work from Mart! I am doing much the same with an earlier crossmember that had been installed by a previous owner using carriage bolts (coach bolts in UK?) that were modified in the same manner as shown by Mart.
I am curious about the grade of bolt recommended as replacement for the original rivets. The stuff I pulled from my frame appear to be only US Grade 2 metallurgy. is that sufficient?
Old 07-11-2020, 05:59 PM   #2
Mart
Mart's Avatar
Ursus, Your comment has set me thinking. I think they are not sufficient grade. I have found some that are 8.8 grade (standard high tensile). I just ordered some so will modify them and swap them in. I'll feel a bit happier myself then.
Unless I'm doing it wrong, looking up various spec sheets and conversion charts, metric grade 8.8 appears to be somewhere between grade 5 and grade 8, towards the grade 5 end.
Mart.
