Old 05-18-2020, 07:27 PM   #1
jg61hawk
Default Cranking Then a Hard Stop...Then Cranks
This started about a month ago....I crank it over with electric start and the motor is turning but suddenly it almost freezes with a hard "stop" but then continues to crank . This may happen once or several times before it starts.
I thought the battery may have been losing it's cranking amps as it was 6 years old, so I got a new dry cell 6 volt. Still doing it. I'm thinking I'll reset timing, but why would timing just fade away? Yes the spark is retarded on starting.
Thoughts
Thanks Jim
jg61hawk is offline   Reply With Quote
Old 05-18-2020, 07:44 PM   #2
wmws
Default Re: Cranking Then a Hard Stop...Then Cranks
I would definitely check the timing. Maybe the screw holding the cam was not tight enough and the cam slipped.
wmws is offline   Reply With Quote
Old 05-18-2020, 07:46 PM   #3
Jacksonlll
Jacksonlll's Avatar
Your lever may be up,but that distributor is not retarded. Check that linkage and make sure the cam is not rotating a little.
Old 05-18-2020, 09:31 PM   #4
Gary WA
Gary WA's Avatar
Thoughts
Thanks Jim
point cap may have closed up!
www.whidbeymodelaclub.com
Old 05-18-2020, 10:46 PM   #5
dumb person
dumb person's Avatar
If the hard stop is near TDC, it's probably the timing rater than a battery/starter.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 05-19-2020, 07:53 AM   #6
Roxo
Roxo's Avatar
I had this same problem when I first got my A. The battery cables were to small for a 6 volt system. It would turn over a few times then suddenly stop on the compression stroke. After a few times of that it would eventually start.
Just something else to try.
Good luck
Roxo is offline   Reply With Quote
Old 05-19-2020, 09:08 PM   #7
katy
katy's Avatar
Can you elaborate? I don't think I've heard of them.
Old 05-19-2020, 11:56 PM   #8
jg61hawk
KATY: The battery has no liquid acid in it, can't spill. Jim's Battery sells them to look exactly like original battery, but many makes are out there. Snyder's sells this version:
OPTIMA BATTERY 6V
A-10655-6
The Optima is a sealed battery so we are able to ship it within the U.S. by UPS or Federal Express.
I my have used the wrong term, "SEALED" it may be Glass Mat :---BU-201a: Absorbent Glass Mat (AGM)
Learn what differentiate AGM from other lead acid battery types
AGM technology became popular in the early 1980s as a sealed lead acid battery for military aircraft, vehicles and UPS to reduce weight and improve reliability. The sulfuric acid is absorbed by a very fine fiberglass mat, making the battery spill-proof. This enables shipment without hazardous material restrictions.
At any rate it can't leak.
Old 05-20-2020, 12:08 AM   #9
Bill G
Bill G's Avatar
Did the original issue get resolved? Curious minds are wondering....
Old 05-20-2020, 10:47 AM   #10
katy
katy's Avatar
jg61hawk, got the picture, thanks for the info, Ken
Old 05-20-2020, 11:58 PM   #11
jg61hawk
Bill G,,,Not sure yet....Today I used the Nu Rex tool and set timing and "step 3" extrta retard" for easy starting. Problem continued. I then did the manual old way and set timing with test light and by hand... I THINK the problem is gone...just not trusting yet...I'll always post the solution...may have a new situation too. Was running good than developed a backfire like an hour later....CONDENSER??? I'll post,
Old 05-21-2020, 08:02 AM   #12
Patrick L.
Patrick L.'s Avatar
Unrelated, you wouldn't happen to be a Studebaker owner are you ?
Old 05-21-2020, 11:24 AM   #13
30 Closed Cab PU
Did the "backfire" sound like a shotgun out the exhaust, or was it more of a cough at the carb?
Old 05-21-2020, 09:17 PM   #14
jg61hawk
Patrick L...Yes 61 hawk.
Old 05-21-2020, 09:23 PM   #15
jg61hawk
The hard stop was apparently related to timing. The backfire was loud shotgun, actually neighbors came over.... I think I resolved that too. Long story: When I got the new battery (Jim' Auto battery formally Antique Auto battery) the instructions were very clear don't let it charge over 8 volts. I ended up moving the brush on the generator all the way up to only get 7 volts. At any rate generator was not charging the battery and when I checked the battery had only 6.02 running. I assume the low voltage was breaking down the spark system, because I upped the charge and things got all better.
Old 05-22-2020, 03:58 AM   #16
Patrick L.
Patrick L.'s Avatar
Glad its fixed. I happen to like Studebakers even more than 'As'. I was born in a Studebaker parts room.
