I had a rear end a few years ago that had the strangest rear drums. It was a 35 or 36. I could not tell witch. The drums had both wheel stud pattern studs. They were swedged in. The drums were open design and I could see the internals. You could mount either 5.5 wheels or wide five ones.
Maybe aftermarket? |
Where did your avatar go, Andy? Maybe you need a new one with a little different flair, for instance: DD
There are 36 rear drums that are two piece. The hub bolts onto the drum using 5 bolts on [probably] 5 1/2" bolt pattern. They are however the large bolt pattern drums as used 36-39
Grumman S-2?
Tim Downtown, Ca |
![]() Douglas B-26 with a prototype Garrett TPE 331 engine glued onto the nose for flight testing. DD ![]() Last edited by V8COOPMAN; 02-25-2020 at 06:20 PM. |
#7 | |
![]() Quote:
I might be wrong but I seem to remember reading that type were early 1936 model year.
Mart. |
I found this one pic on the hamb. Might have been rear only?? Fronts also have windows but are one piece (or at least one bolt pattern).
Edit: this is the thread: https://www.jalopyjournal.com/forum/...oject.1065912/ ![]() Last edited by Mart; 02-25-2020 at 07:06 PM. |
#11 | |
![]() Quote:
