Old 04-24-2019, 06:58 PM   #1
Deuce Man
Deuce Man's Avatar
Default 46 speedometer howling
The speedometer in my 46 started howling today. Is there an easy shot of lubricant fix up, or do I have to climb under there and take it out and send it off? Thanks guys. Rich
Deuce Man is offline   Reply With Quote
Old 04-24-2019, 07:42 PM   #2
paul2748
paul2748's Avatar
Default Re: 46 speedometer howling
Pull the inner cable out and grease it. Not the only reason for them to howl, but maybe the easiest to try.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-24-2019, 09:31 PM   #3
fordor41
fordor41's Avatar
If you pull the speedo there is a small hole for light oil. I used a toothpick to drop oil into the wick as I turned the speedo with a battery drill. That cured my howling on my 41. Other than wiggling around wires, it doesn't come out too badly
fordor41 is offline   Reply With Quote
Old 04-24-2019, 09:34 PM   #4
Tinker
Tinker's Avatar
If you pull it apart use lithium grease when installing. in my opinion.
Old 04-24-2019, 09:38 PM   #5
Deuce Man
Deuce Man's Avatar
Thanks guys. I disconnected the cable from the speedometer and it was dead silent, so it must be in the speedometer head. I have some hypodermic needles from my dogs allergy medication, if I use one to squirt oil into the above mentioned hole, does anyone think it will work without pulling the speedometer? Thanks Rich By the way, Paul, I like your line of thought. My dad would say "just like digging clams, you always take the easy ones first!"
Old 04-25-2019, 01:45 AM   #6
Marvin/TN
Send a message via AIM to Marvin/TN
I had an F-1 that started howling one cold morn on the way to work, I lub the cable and that took care of the noise.
Marvin/TN is offline   Reply With Quote
Old 04-25-2019, 04:57 AM   #7
19Fordy
19Fordy's Avatar
Also, support the cable with a wire tie so that it enters the speedo at 90 degrees and remains at 90 degrees. This reduces stress on cable.
Old 04-25-2019, 05:05 AM   #8
deuce lover
deuce lover's Avatar
The speedo needs to be serviced
Old 04-25-2019, 05:30 AM   #9
big job
big job's Avatar
As said, a small hole at 12 o'clock just after the cable threads. There is a wick in there
that I bet is hard as a rock. I would try and either get wick out or try & soak it with
carb. cleaner. Or pick it out with a needle, then oil, then stick a ball of cotton in and soak
cotton with oil. Most likely never been oiled since day 1....
big job is offline   Reply With Quote
Old 04-25-2019, 05:41 AM   #10
papanick
hay the oil will help some but it will need to be service to get the hard lube out and replace. Let me know if you still need help. papanick
papanick is offline   Reply With Quote
Old 04-25-2019, 08:41 AM   #11
TJ
TJ's Avatar
Just because it was dead silent does not mean it does not need lube. Disconnecting it takes the stress off the cable and it may not make noise if it doesn't have to turn the speedo.
