The Ford Barn
-   -   46 speedometer howling (https://www.fordbarn.com/forum/showthread.php?t=262334)
Deuce Man 04-24-2019 06:58 PM
The speedometer in my 46 started howling today. Is there an easy shot of lubricant fix up, or do I have to climb under there and take it out and send it off? Thanks guys. Rich
paul2748 04-24-2019 07:42 PM
Re: 46 speedometer howling
Pull the inner cable out and grease it. Not the only reason for them to howl, but maybe the easiest to try.
fordor41 04-24-2019 09:31 PM
If you pull the speedo there is a small hole for light oil. I used a toothpick to drop oil into the wick as I turned the speedo with a battery drill. That cured my howling on my 41. Other than wiggling around wires, it doesn't come out too badly
Tinker 04-24-2019 09:34 PM
If you pull it apart use lithium grease when installing. in my opinion.
Deuce Man 04-24-2019 09:38 PM
Thanks guys. I disconnected the cable from the speedometer and it was dead silent, so it must be in the speedometer head. I have some hypodermic needles from my dogs allergy medication, if I use one to squirt oil into the above mentioned hole, does anyone think it will work without pulling the speedometer? Thanks Rich By the way, Paul, I like your line of thought. My dad would say "just like digging clams, you always take the easy ones first!"
Marvin/TN 04-25-2019 01:45 AM
I had an F-1 that started howling one cold morn on the way to work, I lub the cable and that took care of the noise.
19Fordy 04-25-2019 04:57 AM
Also, support the cable with a wire tie so that it enters the speedo at 90 degrees and remains at 90 degrees. This reduces stress on cable.
deuce lover 04-25-2019 05:05 AM
The speedo needs to be serviced
big job 04-25-2019 05:30 AM
As said, a small hole at 12 o'clock just after the cable threads. There is a wick in there
that I bet is hard as a rock. I would try and either get wick out or try & soak it with
carb. cleaner. Or pick it out with a needle, then oil, then stick a ball of cotton in and soak
cotton with oil. Most likely never been oiled since day 1....
papanick 04-25-2019 05:41 AM
hay the oil will help some but it will need to be service to get the hard lube out and replace. Let me know if you still need help. papanick
TJ 04-25-2019 08:41 AM
Just because it was dead silent does not mean it does not need lube. Disconnecting it takes the stress off the cable and it may not make noise if it doesn't have to turn the speedo.
