Old 03-01-2019, 01:31 PM   #1
Werner
Werner's Avatar
Default Engine oil measuring rod
Hello,
can someone please give me the exact measure between "min" and "max" markins? This is no longer visible on my dipstick.
Thanks in advance!
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 03-01-2019, 01:55 PM   #2
Will N
Will N's Avatar
Default Re: Engine oil measuring rod
What I would do to mark a dipstick with no markings is to change the oil in my engine. After refilling it with 4 quarts of oil, and giving it time to have it all drain down to the pan, I'd pull the dipstick and scratch in a line where the oil level is.
Will N is offline   Reply With Quote
Old 03-01-2019, 03:55 PM   #3
Werner
Werner's Avatar
Thanks.
And what is the difference between "max" and "min"?
Werner
Citroen 11 CV, 1947
Old 03-01-2019, 04:04 PM   #4
Synchro909
Synchro909's Avatar
Originally Posted by Werner View Post
Thanks.
Werner, I haven't measured the difference by volume but on the dip stick I just measured there is no line at the "L" level. I would put the lower "L" line 30mm below the full "F" line.
Hope that helps.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 03-01-2019, 04:18 PM   #5
WHN
To get it truly correct. You have to add 4 1/2 quarts of oil at oil change.
1/2 quart is left in dipper tray at time of oil change. Engine takes 5 quarts if your system where completely dry. You had removed oil pan.
Old 03-01-2019, 04:42 PM   #6
johnbuckley
johnbuckley's Avatar
And Werner, just to make sure there's no confusion .... remember, our friends across the water in the USA are referring to a US quart which is 946 ml. In the UK a quart is 1136 ml.
Old 03-01-2019, 04:52 PM   #7
Synchro909
Synchro909's Avatar
Thanks for those numbers, John.
I've always known that the Americans used the same terms but different measures for their volumes and some weights (confusing!) but never got around to researching those figures. After all, the American system is not used anywhere else in the world (that I am aware of).
Old 03-01-2019, 05:25 PM   #8
Benson
MODEL A DIP STICK P/N B-6750-A:
This is the one with the round circle on top end.
Starting from top of dipstick where BOTH halves of stick enter the hole in block:
6 and 5/8ths to F mark
1 and 1/8th from F to L mark.
1/4 inch from L mark to end of stick.
Old 03-01-2019, 08:59 PM   #9
Joe K
Joe K's Avatar
Traditionally, two marks on the automotive dip stick translate into one quart difference.
If you're at the lower mark, you can add a quart and you'll not overfill.
Joe K
Shudda kept the horse.
Old 03-02-2019, 12:36 PM   #10
katy
katy's Avatar
Ford dipsticks:
Old 03-02-2019, 02:06 PM   #11
Anteek29
Anteek29's Avatar
Thanks, katy for that picture!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 03-02-2019, 03:01 PM   #12
oldforder
oldforder's Avatar
The dipstick on my 29 looks like the top picture that is for the v/8, but measures exactly like the bottom picture of the 4 cylinder one. Is that possible or did someone take a v/8 stick and cut it off and re mark it? if so they did a darn nice job.
oldforder is offline   Reply With Quote
Old 03-02-2019, 06:20 PM   #13
Joe K
Joe K's Avatar
More likely an "early" dip-stick. Ford "simplified" the dip-stick from "bayonet" style to the round loop in January 1929.
I acquired a 1930 engine from a Vermont farmer's back lot in 1976 - it had the earlier dip-stick.
Joe K
Old 03-02-2019, 07:23 PM   #14
CT Jack
CT Jack's Avatar
This is simple. Run engine and allow oil to warm. Drain oil completely. Add 4 liters of oil, scribe line on dip stick at level of oil, and mark with a V. V = voll or full
CT Jack is offline   Reply With Quote
Old 03-03-2019, 07:29 AM   #15
Werner
Werner's Avatar
Thank you all for many helpfull hints!
Werner
Citroen 11 CV, 1947
Old 03-04-2019, 09:40 AM   #16
burner31
burner31's Avatar
If engine holds five quarts, with 1/2 quart remaining in the tray, I would think:
Drain oil, add four quarts, mark this level as low, add another 1/2 quart, mark this level as full.
Yes...no...maybe?
Keith
Shawnee OK
'31 SW 160-B
Old 03-04-2019, 10:30 AM   #17
WHN
Yes...no...maybe?
That’s what I would do. You would be on the safe side if it were reading low.
Old 03-04-2019, 10:36 AM   #18
30 Closed Cab PU
Yes...no...maybe?
Ctjack's post is in liters instead of quarts, 4 liters is 4.22 quarts with another half quart in the dipper tray would be 4.72 quarts. Fairly close to full.
Last edited by 30 Closed Cab PU; 03-04-2019 at 04:05 PM. Reason: Changed "4 liters is 4.22 quarts with another quart"
Old 03-04-2019, 01:50 PM   #19
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
I hate to be picky but everyone mentions oil remaining in dipper tray but not in the valve chamber.
Four quarts for a refill is correct. 4.5 will over fill and 4 liters will overfill.
Overfilling will contribute to rear main leak while parked in driveway or slight uphill, and possible blowby with excess being thrown around on cylinder walls and pistons
Richard in Anaheim CA is offline   Reply With Quote
Old 03-04-2019, 01:59 PM   #20
burner31
burner31's Avatar
How much oil remains in the valve chamber?
Anyone?
My guess...not enough to worry about
Keith
Shawnee OK
'31 SW 160-B
