Old 12-21-2018, 11:46 AM   #1
dave11
Default distributor bushings
I need to re bush the distributor shaft (not Model A)
will likely need to turn down an oversize bushing. Are there any specific types of brass bushing best suited for this ...oil lite or ??
Dave
dave11 is offline   Reply With Quote
Old 12-21-2018, 01:14 PM   #2
J Franklin
J Franklin's Avatar
Default Re: distributor bushings
Have you tried to obtain the correct bushings for your application? If you cannot get them I would use the same material as you are replacing.
Old 12-21-2018, 02:32 PM   #3
dave11
This repair is for 31 Plymouth PA equipped with a Delco Remy 629 H
distributor. Pretty sure parts are not available.
Old 12-21-2018, 03:34 PM   #4
Synchro909
Synchro909's Avatar
Brass is entirely the WRONG material to use. They should be bronze, more particularly, Phosphur Bronze. I am assuming the bushes can be lubricated.
You should be able to buy either pre made bushes (We'd look at a bearing supply service) or buy a piece of bronze and make them.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 12-21-2018, 03:39 PM   #5
J Franklin
J Franklin's Avatar
I really doubt that those bushings are rare. Many Delco Remy distributors used the same housing bore size and shaft diameter.
