Old 10-02-2018, 07:35 PM   #1
mill48
mill48's Avatar
Default Engine Ticking sound
Hi guys. I have a 1928 tudor. I recently noticed a ticking sound from the right side of the engine that was not there before. Can anyone steer me in the right direction for diagnostic and possible fix?
mill48 is offline   Reply With Quote
Old 10-02-2018, 07:40 PM   #2
WHN
Default Re: Engine Ticking sound
Does the ticking increase when you rev engine? First thing I would think of is a sticking or slow valve. Do you use MMO in your gas?
Old 10-02-2018, 08:20 PM   #3
Jacksonlll
Jacksonlll's Avatar
Put a new manifold gasket on. Easy job.
Old 10-02-2018, 08:42 PM   #4
daveymc29
daveymc29's Avatar
I had one with a loud ticking sound, put in the MMO and cranked it over with the key off them pulled it to TDC and put about a cup in the suspect cylinder and a week later filled the neighborhood with blue smoke, but ticking all go away. Worked for me and now I use the MMO in our ethanol gas, 4 oz. to a full tank. Been told tranny fluid will do the same. Since I buy MMO by the gallon I find I'm not all that worried about the cost. It is, after all, a ten to thirty thousand dollar toy, so why worry about the minor costs?
daveymc29 is offline   Reply With Quote
Old 10-02-2018, 11:12 PM   #5
mill48
mill48's Avatar
I haven't noticed a difference with the engine revved up yet. I'll check it out tomorrow. I have not added MMO to the gas, but I will try that also. Thanks.
Old 10-03-2018, 12:29 AM   #6
PC/SR
I once had an engine with a tick and no matter what I did it would not go away until I got a new block and built a new engine. Check valve clearance. The real question is performance affected. l gather not. Don't worry too much.
PC/SR is offline   Reply With Quote
Old 10-03-2018, 01:21 AM   #7
Tom Endy
Tom Endy's Avatar
Possible that the cam nut has come loose. Take the little side cover off and see if the cam is loose.
Tom Endy
Old 10-03-2018, 08:36 AM   #8
old31
Does the ticking go away after the engine warms up?
old31 is offline   Reply With Quote
Old 10-03-2018, 12:00 PM   #9
Jim Brierley
If the block is worn in the tappet bores, it will tick. The cure? Oversize tappets.
Old 10-03-2018, 02:03 PM   #10
Patrick L.
Patrick L.'s Avatar
Try to isolate the noise, lifters, exhaust/intake, timing cover. That'll help us.
Old 10-24-2018, 08:55 AM   #11
mill48
mill48's Avatar
Hello guys. Sorry I did not get back sooner to update you. I did as Jackson suggested and changed the intake manifold gasket and the ticking sound disappeared. I added a little MMS to the fuel as an added measureand everything seems fine.
Old 10-24-2018, 09:07 AM   #12
katy
katy's Avatar
MMS?
https://en.wikipedia.org/wiki/Miracl...ral_Supplement
katy is online now   Reply With Quote
Old 10-24-2018, 12:03 PM   #13
100IH
Your ear just went to school.
100IH is offline   Reply With Quote
Old 10-25-2018, 01:26 AM   #14
stillwater
Originally Posted by katy View Post
Hoping he meant MMO, "marvel mystery oil"
that other stuff doesn't sound very good...
stillwater is offline   Reply With Quote
