The Ford Barn
-   -   Engine Ticking sound (https://www.fordbarn.com/forum/showthread.php?t=252386)
mill48 10-02-2018 07:35 PM
Hi guys. I have a 1928 tudor. I recently noticed a ticking sound from the right side of the engine that was not there before. Can anyone steer me in the right direction for diagnostic and possible fix?
WHN 10-02-2018 07:40 PM
Re: Engine Ticking sound
Does the ticking increase when you rev engine? First thing I would think of is a sticking or slow valve. Do you use MMO in your gas?
Jacksonlll 10-02-2018 08:20 PM
Put a new manifold gasket on. Easy job.
daveymc29 10-02-2018 08:42 PM
I had one with a loud ticking sound, put in the MMO and cranked it over with the key off them pulled it to TDC and put about a cup in the suspect cylinder and a week later filled the neighborhood with blue smoke, but ticking all go away. Worked for me and now I use the MMO in our ethanol gas, 4 oz. to a full tank. Been told tranny fluid will do the same. Since I buy MMO by the gallon I find I'm not all that worried about the cost. It is, after all, a ten to thirty thousand dollar toy, so why worry about the minor costs?
mill48 10-02-2018 11:12 PM
I haven't noticed a difference with the engine revved up yet. I'll check it out tomorrow. I have not added MMO to the gas, but I will try that also. Thanks.
PC/SR 10-03-2018 12:29 AM
I once had an engine with a tick and no matter what I did it would not go away until I got a new block and built a new engine. Check valve clearance. The real question is performance affected. l gather not. Don't worry too much.
Tom Endy 10-03-2018 01:21 AM
Possible that the cam nut has come loose. Take the little side cover off and see if the cam is loose.
Tom Endy
old31 10-03-2018 08:36 AM
Does the ticking go away after the engine warms up?
Jim Brierley 10-03-2018 12:00 PM
If the block is worn in the tappet bores, it will tick. The cure? Oversize tappets.
Patrick L. 10-03-2018 02:03 PM
Try to isolate the noise, lifters, exhaust/intake, timing cover. That'll help us.
mill48 10-24-2018 08:55 AM
Hello guys. Sorry I did not get back sooner to update you. I did as Jackson suggested and changed the intake manifold gasket and the ticking sound disappeared. I added a little MMS to the fuel as an added measureand everything seems fine.
katy 10-24-2018 09:07 AM
MMS?
https://en.wikipedia.org/wiki/Miracl...ral_Supplement
100IH 10-24-2018 12:03 PM
Your ear just went to school.
stillwater 10-25-2018 01:26 AM
Originally Posted by katy (Post 1688783)
Hoping he meant MMO, "marvel mystery oil"
that other stuff doesn't sound very good...:eek::D
