08-18-2018, 04:18 PM | #1 |
Signal lights
I installed signal lights on my 1938 Ford Fordor Delux Sedan. All lights work but flash erratically . How do I fix this problem?
08-18-2018, 05:10 PM | #2 |
Re: Signal lights
could it be an earth problem? I find a lot of electrical faults can be traced back to a bad earth.
08-18-2018, 07:03 PM | #3 |
Re: Signal lights
Check all your grounds. Sounds like a classic example of poor grounding.
08-18-2018, 07:06 PM | #4 |
Re: Signal lights
Are any of the bulbs LED?
Thanks Andy 1952 F1 |
08-18-2018, 07:12 PM | #5 |
Re: Signal lights
I used a Napa flasher but my AV8 is 6 volt .
"I can't cry as long as I know the Lord has risen " |
08-18-2018, 10:25 PM | #6 |
Re: Signal lights
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
08-18-2018, 11:01 PM | #7 |
Re: Signal lights
Some times the Bulbs are too small to activate the Flasher. Try a larger size.
08-19-2018, 11:01 AM | #8 |
Re: Signal lights
The NAPA flashers are junk, they are transister style, you want a mechinal type that we used to get, get with Northwestern Auto parts in Grand Rapids Mi and ask for a mechinal they will work,I just went thru this on a 34 truck.
08-19-2018, 06:19 PM | #9 |
Re: Signal lights
my setup is 12v but i had to get a heavy duty non-transistorized unit to make it flash correctly
08-20-2018, 07:29 PM | #10 |
Re: Signal lights
Would you happen to know the exact name or part no. for the flasher and contact info for Northwestern Auto Parts?
08-30-2018, 03:50 PM | #11 |
Re: Signal lights
Hi, I want to thank you for your advice to get a mechanical flasher from Northwestern Auto Parts. I purchased one, installed it and my signal lights work perfect. Thank you.
08-31-2018, 04:27 AM | #12 |
Re: Signal lights
I had the same problem on my 41. Changed the flasher and all was OK
