Old 01-31-2018, 04:51 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default My "B" Block needs a bit of work.
It's .125 over so sleeves will restore it's virginity. A crack between the valve seat and bore will be knitted. Deck the top. Then proceed with the inserts, Riley, ETC.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-31-2018, 07:50 PM   #2
California Travieso
Send a message via Yahoo to California Travieso
Default Re: My "B" Block needs a bit of work.
Originally Posted by Chris Haynes View Post
It's. 125 over so sleeves will restore it's virginity. A crack between the valve seat and bore will be knitted. Deck the top. Then proceed with the inserts, Riley, ETC.
Chris,
Do you already have a a Riley OHV head?
David Serrano
California Travieso is offline   Reply With Quote
Old 01-31-2018, 07:58 PM   #3
johnneilson
Chris,
Make sure the sleeves are stepped in the block to make sure they don't drop.
And make sure to break the sharp edge on the bottom if the pistons skirts sweep past the edge.
I sure hope you got a deal on the block, J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 01-31-2018, 08:14 PM   #4
Chris Haynes
Originally Posted by California Travieso View Post
Chris,
David Serrano
I have the reproduction Riley.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-31-2018, 08:17 PM   #5
Chris Haynes
Originally Posted by johnneilson View Post
Chris,
The block was a iffy as I could see the large bore and crack. So I gambled $350.00 and bought it. If it passes a pressure test I will be happy.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-31-2018, 08:18 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
No harm meant . To save a bunch of money and troubles after the fact , I really believe that you would be better off to look for a better core that wouldn't require sleeving all four cylinders . Big bore is no problem. One hundred and twenty five thousants is already at the practical max . Just my thoughts Good luck whatever .
Old 02-01-2018, 01:12 AM   #7
Chris Haynes
I wish I could find one. It took nearly a year to find this one. Guys with "B" blocks don't want to part company with them. I know one guy who says he has 20 "B" engines and blocks and he won't part with one.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-01-2018, 09:13 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
He'll die with them.
Old 02-01-2018, 09:26 AM   #9
johnneilson
very true dat
afterward, they will show up on Evil bay
Old 02-01-2018, 09:47 AM   #10
Marshall V. Daut
"He'll die with them."
If this guy has 20 Model "B" blocks, he'll probably die of a CRACK overdose.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 02-01-2018, 09:53 AM   #11
Railcarmover
.125 and cracked? and youre going to fix it and run a 5k head?...well,your signature line is right.speed does cost money..in your case lots of money,lots and lots of money. Did that anchor come with a C crank?
Railcarmover is offline   Reply With Quote
Old 02-01-2018, 11:11 AM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Dog here,
Remember, once CRACKED, always CRACKED & CRACKING
Buster T. Iwarnedyou
"THE ASSISTANT GURU OF STUFF"
Old 02-01-2018, 11:24 AM   #13
Purdy Swoft
Again , good luck with your B block . Be sure to give plenty of piston to cylinder wall clearance and ring gap . Clearance will help it run cooler and faster !!! Hopefully it won't run too hot .
Old 02-01-2018, 12:40 PM   #14
Jim Brierley
Nothing wrong with a 4" bore, if they are round and straight I would use as-is. 4" is the first thing racers did, some went as far as 4.060" but this requires moving the center-line to give room between cylinders for the gasket. As Purdy says, give plenty of clearance.
Old 02-01-2018, 01:18 PM   #15
Purdy Swoft
My biggest concern would be heat transfer with a sleeved engine . Sleeves can't transfer heat as well as the original cylinder walls . The water jacket doesn't extend very far on the A & B engines and doesn't cool the full length of the cylinder nearly as well as later engines.
Old 02-01-2018, 01:32 PM   #16
Railcarmover
The only heat transfer issue created by sleeving is the friction of.your dollars leaving your wallet.
Old 02-01-2018, 01:51 PM   #17
Chris Haynes
Originally Posted by BILL WILLIAMSON View Post
Dog here,
Bill,
I'm having the crack pinned. Fortunately it is on an intake valve that won't be used with the Riley head.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-01-2018, 01:52 PM   #18
Chris Haynes
[QUOTE=Railcarmover;1587102]
I have a NOS Eubanks crank.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-01-2018, 01:57 PM   #19
Chris Haynes
He buys estates of Ford cars and parts. He makes his living selling parts and working on cars. Trying to get a part from him is difficult at best.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-01-2018, 02:54 PM   #20
hardtimes
hardtimes's Avatar
Yeah, I know this guy...well I thought at one time that I knew this guy. You evaluation is right on, IMO ! I think that Jim B has good info that he stated. Nothing wrong with 4" bore and there is good to be gained by such big bore...namely power, which is what you/me/others are
spending for/ striving for,eh ! Otherwise, stay with stock bore A engine/block.
All my engines, that I build have 4" bore, but starting out with the BEST B block that you can get is important ! Cracks can be and are repaired satisfactorily , but I'd rather not start there.
'Speed costs, how fast do you can to go'...is a truism learned one way or the other. Doesn't mean that we can't be smart with spending our $. I think that it is a disease/itch that can't be scratched !
Sometimes PATIENCE is less costly. This I've learned and occasionally.. still do not listen to myself !
HEY TOD...where the heck are you with the 5x5 new iron blocks !!
BTW Chris...I've sent you a PM.
