Old 01-05-2018, 10:41 AM   #1
Leatherback 57
Leatherback 57's Avatar
Default Fan
I determined that I have a blown head gasket between 2 and 3 cylinders.I have a four blade fan and going to install the thrust collar in front to eliminate end play. Was debating going back to 2 blade fan making it easier to removed waterpump in future.Never had cooling issues. Actually runs cold even in hot weather. Appreciate opnions.
Leatherback 57 is offline   Reply With Quote
Old 01-05-2018, 10:55 AM   #2
captndan
captndan's Avatar
Default Re: Fan
Two blade just because of the water pump. No need to kick your self later on.
captndan is offline   Reply With Quote
Old 01-05-2018, 11:09 AM   #3
burner31
burner31's Avatar
Default Re: Fan
Two blade
It's one thing all the looky-loos notice when looking at your engine, the other is the distributor and plug straps
Keith
Shawnee OK
'31 SW 160-B
Old 01-05-2018, 12:48 PM   #4
1930-Pickup
Default Re: Fan
Originally Posted by burner31 View Post
Two blade
x3. I got the cast aluminum one. Quality seems good.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 01-05-2018, 01:20 PM   #5
WHN
Default Re: Fan
Two blade aluminum. After about 15 mph the fan really doesn’t do much anyway.
I agree also that it looks better. Enjoy.
Old 01-05-2018, 02:21 PM   #6
divcoone
divcoone's Avatar
Default Re: Fan
I convinced myself that the 6 blade is probably better balanced. Other than that, I can't tell the difference.
divcoone is offline   Reply With Quote
Old 01-05-2018, 03:04 PM   #7
Chris Haynes
Chris Haynes's Avatar
Default Re: Fan
If you remove the studs from the head and use this kit it makes removing the water pump with the radiator in place easy.
http://www.snydersantiqueauto.com/pump-mounting-kit
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-05-2018, 06:45 PM   #8
Nathan_1929
Nathan_1929's Avatar
Default Re: Fan
Just beware, I replaced the 4-blade with a new 2-blade and it just touches the radiator hose now. Haven't yet pondered enough about what I'm going to do to remedy the situation. Maybe just put an extra set of rubbers under the radiator mounts to raise it up a hair.. I'm not running the hood anyway.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic
Nathan_1929 is offline   Reply With Quote
Old 01-05-2018, 11:50 PM   #9
31a
Default Re: Fan
Two blade Bob
31a is offline   Reply With Quote
Old 01-06-2018, 01:08 PM   #10
old31
Default Re: Fan
I changed from a 4 to a 2 and used the Snyders kit.
old31 is offline   Reply With Quote
