Old 09-01-2017, 09:41 PM   #1
Denis45700
Default 1931 a truck
I am trying to find info on the engine as it has a weird serial number on it
Also on the other side are these numbers. T
Denis45700 is offline   Reply With Quote
Old 09-01-2017, 10:48 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: 1931 a truck
Someone replaced it with a new one sometime in the past. This is based on what looks like a cast number pad and not one that is ground down.
Your block is a "diamond block". Your casting date is, August 24th, 1937. see the Diamond shape <> to the right of the valve cover near the timing gear cover.
Old 09-01-2017, 11:18 PM   #3
Larry Jenkins
Also looks like it has a 30 grill shell..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 09-02-2017, 10:17 AM   #4
Anteek29
Anteek29's Avatar
I have never seen this style water pump?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 09-02-2017, 11:10 AM   #5
Denis45700
Thank you Mike.
Old 09-02-2017, 11:40 AM   #6
jm29henry
jm29henry's Avatar
Cool truck I am also interested by the water pump
jm29henry is offline   Reply With Quote
Old 09-02-2017, 04:18 PM   #7
Denis45700
I just got the truck. I know absolutely nothing about model a's.
Old 09-02-2017, 07:32 PM   #8
SSsssteamer
SSsssteamer's Avatar
For what it is worth: Your indented firewall is a later one of 1931 issue. The earlier Fords had a flat firewall and the gasoline shut off valve was located inside above the choke rod, instead of a shut off on the outside of the firewall like yours. Looks as though you have a pick up cab build by Budd, as it has a steel top instead of a fabric covered top. Two side mounts? A bit busy for a pick up which ordinarily came with just only one spare tire on the left front fender. You exhaust manifold is built by Autolite and it is missing its top cover (plenum) that directs the hot air into the passenger compartment through the hole in the firewall located at the passenger's toes. You have a wonderful model A Ford. Congratulations.
SSsssteamer is offline   Reply With Quote
Old 09-02-2017, 07:46 PM   #9
Roger Green
Denis45700,
If you are new to Model A's, my first suggestion is to find & join a Model A club. I worked for the Uncle Sam and moved a lot; I know there are a lot of good clubs out there.
Random ROG
Roger Green is offline   Reply With Quote
Old 09-03-2017, 06:40 PM   #10
Denis45700
Thank you very much for the information.
Old 09-03-2017, 06:40 PM   #11
Denis45700
Originally Posted by Roger Green View Post
Denis45700,
Random ROG
Thanks.
Old 10-29-2017, 09:46 PM   #12
31a
How many screws on the sun visor? I have a Budd cab pickup and was told it is supposed to have 8 I have 6 and think mine is correct thanks Bob
31a is offline   Reply With Quote
Old 11-09-2017, 11:48 AM   #13
edgar44
Jay McCord is starting up a Budd Special Interest Group so you might want to look into that. Jay is currently a member of the 2017-2018 MAFCA board. From what I know, Budd trucks were only built in late '31 so the indented firewall makes sense. Steel roof too of course! What serial number do you find on the body? (Found on the cross member inside the cab just in front of the seat in the middle)
edgar44 is offline   Reply With Quote
Old 11-09-2017, 10:13 PM   #14
farmer dave
i also have same water pump in my 31 deluxe delivery has a bearing each end got it club flea market cant find any info would like to know who made it
farmer dave is offline   Reply With Quote
Old 11-10-2017, 07:07 AM   #15
History
History's Avatar
What is the chain for that drapes across the breather tube?
History is offline   Reply With Quote
Old 11-10-2017, 08:13 AM   #16
frank mcdaniels
frank mcdaniels's Avatar
I also wondered about the chain . This forum is so great ,there are so many really great guys on here so willing to share their knowledge. I really like your pickup and it looks as though it had some good previous owners. You have a tillitson carb and the sediment bulb down by it is also an add on. I can't see any problem with this. I suppose the former owner was getting some sediment from the tank. Watch the bulb and see if it accumulates in there, and occationally empty it. Have fun with this baby, Frank
frank mcdaniels is offline   Reply With Quote
Old 11-10-2017, 08:22 AM   #17
Keith True
Keith True's Avatar
That chain is for when the air maze falls off,so you don't lose it in the street.My first A came to me like that,and it had been parked since 1954.
Old 11-15-2017, 07:34 PM   #18
Denis45700
My has 6 screws
Old 11-15-2017, 07:40 PM   #19
Denis45700
Thank you Frank.
Old 11-15-2017, 08:19 PM   #20
glenn in camino
glenn in camino's Avatar
T6hat water pump is filled with waterproof grease. They don't leak.
