The Ford Barn
-   -   1931 a truck (https://www.fordbarn.com/forum/showthread.php?t=228196)
Denis45700 09-01-2017 09:41 PM
1931 a truck
I am trying to find info on the engine as it has a weird serial number on ithttps://uploads.tapatalk-cdn.com/201...97cd865675.jpghttps://uploads.tapatalk-cdn.com/201...bd2145313a.jpghttps://uploads.tapatalk-cdn.com/201...2599cbd104.jpg
Sent from my iPhone using Tapatalkhttps://uploads.tapatalk-cdn.com/201...f390b04b7b.jpg
https://uploads.tapatalk-cdn.com/201...3003cc89ad.jpg
Also on the other side are these numbers. T
Mike V. Florida 09-01-2017 10:48 PM
Re: 1931 a truck
Someone replaced it with a new one sometime in the past. This is based on what looks like a cast number pad and not one that is ground down.
Your block is a "diamond block". Your casting date is, August 24th, 1937. see the Diamond shape <> to the right of the valve cover near the timing gear cover.
Larry Jenkins 09-01-2017 11:18 PM
Re: 1931 a truck
Also looks like it has a 30 grill shell..
Anteek29 09-02-2017 10:17 AM
Re: 1931 a truck
I have never seen this style water pump?
Denis45700 09-02-2017 11:10 AM
Re: 1931 a truck
Thank you Mike.
jm29henry 09-02-2017 11:40 AM
Re: 1931 a truck
Cool truck I am also interested by the water pump
Denis45700 09-02-2017 04:18 PM
Re: 1931 a truck
I just got the truck. I know absolutely nothing about model a's.
SSsssteamer 09-02-2017 07:32 PM
Re: 1931 a truck
For what it is worth: Your indented firewall is a later one of 1931 issue. The earlier Fords had a flat firewall and the gasoline shut off valve was located inside above the choke rod, instead of a shut off on the outside of the firewall like yours. Looks as though you have a pick up cab build by Budd, as it has a steel top instead of a fabric covered top. Two side mounts? A bit busy for a pick up which ordinarily came with just only one spare tire on the left front fender. You exhaust manifold is built by Autolite and it is missing its top cover (plenum) that directs the hot air into the passenger compartment through the hole in the firewall located at the passenger's toes. You have a wonderful model A Ford. Congratulations.
Roger Green 09-02-2017 07:46 PM
Re: 1931 a truck
Denis45700,
If you are new to Model A's, my first suggestion is to find & join a Model A club. I worked for the Uncle Sam and moved a lot; I know there are a lot of good clubs out there.
Random ROG
Denis45700 09-03-2017 06:40 PM
Re: 1931 a truck
Thank you very much for the information.
Re: 1931 a truck
Originally Posted by Roger Green (Post 1521958)
Denis45700,
Random ROG
Thanks.
31a 10-29-2017 09:46 PM
Re: 1931 a truck
How many screws on the sun visor? I have a Budd cab pickup and was told it is supposed to have 8 I have 6 and think mine is correct thanks Bob
edgar44 11-09-2017 11:48 AM
Re: 1931 a truck
Jay McCord is starting up a Budd Special Interest Group so you might want to look into that. Jay is currently a member of the 2017-2018 MAFCA board. From what I know, Budd trucks were only built in late '31 so the indented firewall makes sense. Steel roof too of course! What serial number do you find on the body? (Found on the cross member inside the cab just in front of the seat in the middle)
farmer dave 11-09-2017 10:13 PM
Re: 1931 a truck
i also have same water pump in my 31 deluxe delivery has a bearing each end got it club flea market cant find any info would like to know who made it
History 11-10-2017 07:07 AM
Re: 1931 a truck
What is the chain for that drapes across the breather tube?
frank mcdaniels 11-10-2017 08:13 AM
Re: 1931 a truck
I also wondered about the chain . This forum is so great ,there are so many really great guys on here so willing to share their knowledge. I really like your pickup and it looks as though it had some good previous owners. You have a tillitson carb and the sediment bulb down by it is also an add on. I can't see any problem with this. I suppose the former owner was getting some sediment from the tank. Watch the bulb and see if it accumulates in there, and occationally empty it. Have fun with this baby, Frank
Keith True 11-10-2017 08:22 AM
Re: 1931 a truck
That chain is for when the air maze falls off,so you don't lose it in the street.My first A came to me like that,and it had been parked since 1954.
Denis45700 11-15-2017 07:34 PM
Re: 1931 a truck
My has 6 screws
Denis45700 11-15-2017 07:40 PM
Re: 1931 a truck
Thank you Frank.
glenn in camino 11-15-2017 08:19 PM
Re: 1931 a truck
T6hat water pump is filled with waterproof grease. They don't leak.
