28-29 front fender brackets, is there a left and right or both the same?29 sport coupe
www.whidbeymodelaclub.com |
No, the fender brackets are swapable. And depending on what month, were either forged or stamped.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
Front fender brackets were forged in 1928. The forged front brackets were carried over into early 1929 for many assembly plants. My early 1929 phaeton has forged front brackets and stamped rear fender brackets.
Rusty Nelson |
Dog
![]() I'll add this to my TRIVIA info, to RECOMEMBER ![]() ![]() Buster T. ![]()
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 08-17-2017 at 06:03 PM. |
They are the same and usually need to be bent to fit the fender.
#6 | |
Ted used a BIG ROSEBUD torch, to "shape" his ![]() ![]() Bill W.
Thanks all must be bent not lining up with fender bolt hole they are forged.
You can bend the forged brackets without fear of breaking them, unlike the cast repros that will break easily. They can be bent cold or with heat. I once straightened out a forged rear coupe bracket that look like a horseshoe (must have been in an accident) to align it with an unbend bracket I had.
Rusty Nelson |
#9 | |
![]() Quote:
I "think" I saw you, as a Blacksmith, in an OLD Western Movie ![]() ![]() Bill Brokenshoe
Rusty,
I just straighten one, to fit your fender, with my torch. I left it cool on its own because I was worried about tempering it. Didn't want to try bending it cold, but I would like to see how they bend on a junk one sometime. Pat |
Gary, there were also forged front fender brackets used in 1930. If things are off more than a little this could be the problem. It's easy to tell them apart by the shape where they attach to the frame - post a picture if there's any doubt about which you have.
Also, the distance from the mount at the bottom to the two holes for the fender are different.
#13 |
I am attaching a picture of some forged 1930 front fender brackets I have. Note the bosses for the larger bottom bolts - the lower boss is the same thickness as the top 2 bolts. 28/29 forged brackets have a much thicker lower boss - sorry I don't have a picture handy of the 28/29 bottom area of the brackets. Some time I will take a picture of the two together to easily show the differences.
Rusty Nelson |
#14 | |
![]() Quote:
#15 |
Don't forget to insert the 2 headlight bar bolts through the fender and bracket holes. I got the outer fender carriage bolt to fit in one of my vehicles, but the headlight bar would not fit due to the bracket holes being off 1/4" to 5/16".
Actually I have 6 or 8 front brackets, so to easy the pain of fitting and bending them, I try different ones until I get a close fit. I don't know what I will do when I get down to the last few brackets for my 4th vehicle and only have two or three left, I guess I will have to start bending them. Rusty Nelson |
#16 | |
![]() Quote:
#17 |
Good job Vern Ready to start it up!!??
