Old 07-10-2017, 09:20 PM   #1
Larry Jenkins
Default Settle a friendly difference of opinion..
A Model A buddy and I were talking about the "B" engine. He thinks it was introduced in the Model A in late 1931.
I think it was not available until the 1932 Model B was introduced along with the V8 option.
Who wins the cold one?
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 07-10-2017, 09:25 PM   #2
steve s
steve s's Avatar
Default Re: Settle a friendly difference of opinion..
you win.
steve s is offline   Reply With Quote
Old 07-10-2017, 09:35 PM   #3
40 Deluxe
He may have seen a car with the optional "police" head, which was labeled 'B'. Since 'B' on the head was already taken by the A police head when the 'B' engine came out, the heads on the 'B' engine were labeled "C". However there was never a Model C engine.
Old 07-10-2017, 09:52 PM   #4
Larry Jenkins
About what I told him today. He was surprised when I said there was never a "C" engine..
He claims he has a piece of paper showing the "B" engine in a 1931 Model A. Probably just as you described..
Old 07-10-2017, 11:03 PM   #5
Charlie Stephens
That is great news! We are never too old to learn. Please have him give you copy you can post as am sure everyone would enjoy seeing it..
Charlie Stephens
Old 07-10-2017, 11:07 PM   #6
daveymc29
daveymc29's Avatar
I'm running two A's with the Police "B" head. Have yet to find a "C" head.
daveymc29 is offline   Reply With Quote
Old 07-10-2017, 11:37 PM   #7
Larry Jenkins
My 30 Coupe, long sold.. had a "B" engine with a "C" head.. Talk about non-standard stuff.. Probably worth about 5 million now..
Old 07-10-2017, 11:41 PM   #8
Charlie Stephens
Almost all the heads used on the 1932-34 four cylinder engines had a block letter "C" on them. The part number of the head with the block "C" was "B-6050".
Charlie Stephens
Old 07-11-2017, 09:30 AM   #9
mike657894
mike657894's Avatar
I see the major difference being the water kneck on the A head. The bolt patterns look the same can you put a b head on a A engine? or A a high comp head on a b engine.
mike657894 is offline   Reply With Quote
Old 07-11-2017, 01:12 PM   #10
Chris Haynes
Chris Haynes's Avatar
You can put one on an A engine but you must use the B water pump.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-11-2017, 01:29 PM   #11
Charlie Stephens
Chris is correct but I wanted to add that you need to use the "B" head gasket as the combustion chamber is shaped different. In answer to the other question in the original post yes you can run a Model A high compression head on a Model B engine (I an currently doing it). You also need to run the Model B gasket with the Model A high compression head.
Charlie Stephens
Old 07-12-2017, 06:49 AM   #12
Growley bear
A true "B" engine will have a mounting pad for a fuel pump. The head is not a very good indicator.
Growley bear is offline   Reply With Quote
