The Ford Barn
-   -   Settle a friendly difference of opinion.. (https://www.fordbarn.com/forum/showthread.php?t=224414)
Larry Jenkins 07-10-2017 09:20 PM
A Model A buddy and I were talking about the "B" engine. He thinks it was introduced in the Model A in late 1931.
I think it was not available until the 1932 Model B was introduced along with the V8 option.
Who wins the cold one?
steve s 07-10-2017 09:25 PM
Re: Settle a friendly difference of opinion..
you win.
40 Deluxe 07-10-2017 09:35 PM
He may have seen a car with the optional "police" head, which was labeled 'B'. Since 'B' on the head was already taken by the A police head when the 'B' engine came out, the heads on the 'B' engine were labeled "C". However there was never a Model C engine.
Larry Jenkins 07-10-2017 09:52 PM
About what I told him today. He was surprised when I said there was never a "C" engine..
He claims he has a piece of paper showing the "B" engine in a 1931 Model A. Probably just as you described..
Charlie Stephens 07-10-2017 11:03 PM
That is great news! We are never too old to learn. Please have him give you copy you can post as am sure everyone would enjoy seeing it..
Charlie Stephens
daveymc29 07-10-2017 11:07 PM
I'm running two A's with the Police "B" head. Have yet to find a "C" head.
Larry Jenkins 07-10-2017 11:37 PM
My 30 Coupe, long sold.. had a "B" engine with a "C" head.. Talk about non-standard stuff.. Probably worth about 5 million now.. ;)
Charlie Stephens 07-10-2017 11:41 PM
1 Attachment(s)
Almost all the heads used on the 1932-34 four cylinder engines had a block letter "C" on them. The part number of the head with the block "C" was "B-6050".
Charlie Stephens
mike657894 07-11-2017 09:30 AM
I see the major difference being the water kneck on the A head. The bolt patterns look the same can you put a b head on a A engine? or A a high comp head on a b engine.
Chris Haynes 07-11-2017 01:12 PM
You can put one on an A engine but you must use the B water pump.
Charlie Stephens 07-11-2017 01:29 PM
Chris is correct but I wanted to add that you need to use the "B" head gasket as the combustion chamber is shaped different. In answer to the other question in the original post yes you can run a Model A high compression head on a Model B engine (I an currently doing it). You also need to run the Model B gasket with the Model A high compression head.
Charlie Stephens
Growley bear 07-12-2017 06:49 AM
A true "B" engine will have a mounting pad for a fuel pump. The head is not a very good indicator.
