My A's coil failed over the weekend. I need a bit of education on what and where to buy. Does any supplier provide a better coil than the others? Is there a coil that is more reliable than the others? Is a hotter coil better? What are the pros and cons of a hotter coil? Appreciate your recommendations on what and where to buy. Thanks.
Based on information from knowledgeable people on this forum, I purchased a Pertronix 40111 1.5 ohm "Flame Thrower" coil several years ago. Very happy with it.
If at first you don't succeed, skydiving isn't for you! You don't need a parachute to skydive, you only need a parachute to skydive twice. |
I've read here that many coils are oil filled. If you mount them in the stock location, upside down, they can eventually leak.
I went to buy a 6v coil at the local o'reillys and when I shook it you could hear the oil sloshing around. I think the original coils were tar filled or something similar. I see the Pertonix 40111 mentioned above is epoxy filled....nothing to leak out....maybe I'll get one too...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
Tar or Epoxy filled is best when mounted upside down like original.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
There is an oil filled version, with a similar number, considerably less expensive.
This is the epoxy filled version... https://www.summitracing.com/parts/p...Fcdefgod8HoIGw
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 05-23-2017 at 01:46 PM. Reason: Accuracy |
Bob |
Speaking of coils I picked up a slant pole coil that would be appropriate for my early 29 tudor. After cleaning I noticed the lightening like trace on the Bakelite insulator (see pic). Should I give it a try anyway, or would I be asking for trouble?
I'd fill the crack with super glue and give it a try.
Be sure the first thing to go on each post is an insulating washer. |
How did you determine that it was the coil that failed?
All steel from pedal to wheel |
#11 | |
![]() Quote:
They say their oil filled coil is available in both 1.5 ohm and 3.0 ohm versions, with either oil-filled coil. What is the difference in the vibration resistant epoxy version regarding it's ohm's rating ?? And is any of this necessary in a Model A ? |
Been using Flame Thrower coils on a heavy boat for years. Very robust!
#13 | |
![]() Quote:
I don't know if your one is OK Paul, But a fellow drove to my house a couple weeks ago in his Canadian 29 Tudor, It still had the Original Slant Pole coil on it and it was still working fine . I thought a tribute to Henry and his Well Built Car |
#14 | |
![]() Quote:
You didn't mention whether your car is 6 or 12 volts. The pertronix 40111 is a 1.5 ohm epoxy coil. so, 6v; no resistor 12v; resistor needed Just make coil is installed same as battery polarity. battery + grd; + coil to points battery - grd; - coil to points |
#15 | |
![]() Quote:
"The pertronix 40111 is a 1.5 ohm epoxy coil. so, 6v; no resistor 12v; resistor needed" Joe
#16 |
agreed, I have a coil with 1000 rust pit holes in it and Ive seen one way worse where the outer case had a good 1/4 of the top half rusted away still tests great and produces a nice hot blue spark on the coil tester.
#17 |
If you are using a 6 volt system then a 6 or 12 volt coil will do , no resister required . But if using a 12 volt system then a resister is required.
#18 |
If you have 12v, use the Pertronix 40611 3 ohm coil. No resistor needed as it has an internal resistor. It is epoxy filled.
#19 |
I would go one step further and clean out the crack as it may contain material that will still allow the spark to follow the path.
#20 |
Prior owner of that coil may have had a problem with it...just be aware it may fail at some point due to that crack.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
