Need a New Coil My A's coil failed over the weekend. I need a bit of education on what and where to buy. Does any supplier provide a better coil than the others? Is there a coil that is more reliable than the others? Is a hotter coil better? What are the pros and cons of a hotter coil? Appreciate your recommendations on what and where to buy. Thanks.
Re: Need a New Coil Based on information from knowledgeable people on this forum, I purchased a Pertronix 40111 1.5 ohm "Flame Thrower" coil several years ago. Very happy with it. :)
Re: Need a New Coil I've read here that many coils are oil filled. If you mount them in the stock location, upside down, they can eventually leak.
I went to buy a 6v coil at the local o'reillys and when I shook it you could hear the oil sloshing around. I think the original coils were tar filled or something similar. I see the Pertonix 40111 mentioned above is epoxy filled....nothing to leak out....maybe I'll get one too... |
Re: Need a New Coil Tar or Epoxy filled is best when mounted upside down like original.
Re: Need a New Coil There is an oil filled version, with a similar number, considerably less expensive.
This is the epoxy filled version... https://www.summitracing.com/parts/p...Fcdefgod8HoIGw |
Re: Need a New Coil The oil filled is 40011 the epoxy is 40111.
Bob |
Re: Need a New Coil Quote:
Re: Need a New Coil 1 Attachment(s)
Speaking of coils I picked up a slant pole coil that would be appropriate for my early 29 tudor. After cleaning I noticed the lightening like trace on the Bakelite insulator (see pic). Should I give it a try anyway, or would I be asking for trouble?
Re: Need a New Coil I'd fill the crack with super glue and give it a try.
Be sure the first thing to go on each post is an insulating washer. |
They say their oil filled coil is available in both 1.5 ohm and 3.0 ohm versions, with either oil-filled coil. What is the difference in the vibration resistant epoxy version regarding it's ohm's rating ?? And is any of this necessary in a Model A ? |
Re: Need a New Coil Been using Flame Thrower coils on a heavy boat for years. Very robust!
I don't know if your one is OK Paul, But a fellow drove to my house a couple weeks ago in his Canadian 29 Tudor, It still had the Original Slant Pole coil on it and it was still working fine . I thought a tribute to Henry and his Well Built Car |
You didn't mention whether your car is 6 or 12 volts. The pertronix 40111 is a 1.5 ohm epoxy coil. so, 6v; no resistor 12v; resistor needed Just make coil is installed same as battery polarity. battery + grd; + coil to points battery - grd; - coil to points |
"The pertronix 40111 is a 1.5 ohm epoxy coil. so, 6v; no resistor 12v; resistor needed" Joe |
Re: Need a New Coil If you are using a 6 volt system then a 6 or 12 volt coil will do , no resister required . But if using a 12 volt system then a resister is required.
Re: Need a New Coil Prior owner of that coil may have had a problem with it...just be aware it may fail at some point due to that crack.
