#21 |
Hi tom, yeah the spark is ok... but I found more problems when draining the gas... the gasket in the sediment bowl has completely disintigrated , bits of black gasket in the bowl and carb. Bowl and carb cleaned out and blow with air.
Guess this won't be fixed today after all.
I'm quickly becoming a "Specialist" in which I know more and more about less and less until I know everything about Nothing! ![]() |
#22 |
You say you have spark at the points,but do you actually have spark at the plugs?I didn't see that,maybe I missed it.
#23 |
Keith: you are correct...i din't answer that because i don't know the correct way to rtest that.
#24 |
Take pug out rest on metal bottom of plug on top of head or nut (good ground surface connect copper strip, turn over motor, it some times takes two people in a model A. One to look for spark one to crank or push button also try looking at dusk it will help you see the spark better if your eyes aren't that great. I for one would just throw. A new set of plugs in it. And test with those I've had corrosion on the copper strips leading to dizzy that stopped spark also if spark is at all orange and not blue your coil went bad from condinsation while sitting. And that's your problem. no matter how bad your carb is if you at least have good spark and some gass it should cough and fire.
#25 |
Tom: i have a good spark from the coil wire t the head nut.. so I guess it's boiled down to fresh gas, I won't be able to try that until the new sediment bowl gaskets come in. Whew this ahs been a long day already...lol
#26 |
#27 |
You can also hang a small can of gas temporarily
1/4" piece of rubber hose from the can connected to the steel line end that would go to the sediment bulb.. youll need to get the gravity flow going to do this... |
#28 |
Thanks Mitch..I'll try that tomorrow... I talked to Snyders and told them about the black rubber gaskets deal(talked with Tom) he sent some free cork gaskets.
I'll try the rubber hose till they get here. I had my wife do the inside controls and I sprayed carb cleaner into the carb and it fired right up!! twice in fact.. Nice sound!! Now i forgot is it the gasket first or the screen first when reassembling the sediment bowl?? must be the CRS?? The spark plugs were sparking against the head nut, so i also cleaned all the ends of the brass connectors to dist top. Thanks guys for all your suggestions and help, as always.. ![]()
#29 |
Hi Candle,
When held upright, top open parts of glass sediment bowls have a smaller diameter "recessed", glass circular inner surface for the screen to rest on, and immediately adjacent, it has a larger diameter "raised", glass outer circular surface for the gasket to rest on. After the glass bowl is installed and tightened, the circular gasket should contact the upper, "solid" metal circular surface and the lower, "solid" circular glass surface. The perforated fuel screen should never become sandwiched between the gasket and either the solid metal above, or the solid glass below, thus allowing very thin fuel to escape. With CSRS, like with most of us, after becoming confused about "exact" fuel screen placement, just try to remember why nobody makes gasoline cans out of Model A fuel filter screen material. Last edited by H. L. Chauvin; 04-06-2017 at 06:32 PM. Reason: typo |
#30 |
Did you ever check the timing??
#31 |
Thanks H.L.
#32 |
Yes the timing is dead on...
#33 | |
![]() Quote:
If not, check cap, rotor, condenser... |
#34 |
Coils RARELY fail, it's usually the crap that controls it that goes AMUCK!
Using a cheep test light & getting used to how BRIGHT it glows on a GOOD source, is your BEST, QUICK Friend. You CAN'T screw something up using it! An inexpensive Multimeter is better. They're not SPOOKY to use, PLAY with it, read the instructions, find a "U" tube video on its' use. You can "play-like" you're an EXPERT & impress folks. Lurn some ELECTRONIC sounding wurds & terms & they'll want to HIRE you!!! Even an OLD Encyclopedia can help you with some BASIC electrical knowledge. Bill Babble
#35 | |
![]() Quote:
Glad you got it narrowed down to carb/fuel issue.
#36 | |
![]() Quote:
That filter is OFTEN overlooked ![]() Bill Nosey
#37 |
He said it fired on spray twice... that means he is getting spark to the plugs
#38 |
No now ignitions mostly ruled out I'd pull drain plug from bottom of carb.
1) make sure gas is actually getting past siffter screen and past float needle and seat valve 2) Fill a mason jar with gas from drain plug at carb make sure the streem is constraint let the jar fill to flush the bowl. Once full let the jar sit and settle for a half hour. See if there's separation of gas ethanol and water see if there's sediment on the bottom a lot can be December from a mason jar of gas. Bill, your partly right (old coils rearly go but I tell you the new ones go I had one from Macs fail on me in my A once when I first got her. (Put original in never had a problem) had an excel coil go in my jeep after 5 months and had one go in my boat (that one was old but boats take more abuse) the problem is the crimp on the top were they are sealed don't always seal and moisture gets in and that's that. Also had a coils go on my Harley too In the past. |
#39 |
hey guys....i want to thank everyone for all the fast help, all the great tips and tricks....I haven't done an A in 25 years...gees have i forgotten a lot of stuff..!! Well I think it was all narrowed down to the old gas, ( stuff i drained from the carb and tank I threw on some wood in the fire pit and it would hardly even burn..lol no wonder i was having such a hard time.. Still waiting for the gaskets for the sediment bowl but in the mean time i made a temp tank out of an old weed wacker tank and a spare gas line i had. It worked great. it ran well until i ran out of gas(fresh gas).
To answer some things, the spark at plugs was fine, the carb was dry(i drained it when i parked it) it's brandy new, I checked the inlet filter and yes it has some black rubber pieces in it as well as the carb bowl. In all the excitement of it starting, i forgot to check the amp to see if it was charging...guess that will be the next hurdle. Thanks again to all...I really appreciate it. ![]() ![]() Michael...
