Does anyone have a picture of the bare frame for a 37 bed mounted on a chassis with the wooden blocks correctly placed underneath? A shot of a complete bed on frame from underneath might also work to point me in the right direction. Thanks.
was this helpful?
Maybe these will help some. These are for 40-41. Don't think there is much difference.
If you are using a reproduction bed -- early ones did not have the right angle for the frame of the bed matching the contour of the vehicle frame
There is suppose to be a rear cross member between the rear frame rails. There should be 4 mounting places on each side of the bed. Three use the special head bolts with the square hole in them and the last one (at the end of the bed toward the cab) was a carriage bolt. Last edited by nelsb01; 03-09-2017 at 04:30 PM. Reason: add more information |
1935-37 the rear mount bolt through the block was just in the middle of the bed, no crossmember.
1938-41 are quite a bit different... they have wood cross blocks front and rear. |
