Old 01-11-2017, 11:20 PM   #1
josh1331
Default Who sells best master cylinder for 40
Does anyone know a vendor who sells master cylinders that are best quality on market. Need one very shortly.
josh1331 is offline   Reply With Quote
Old 01-12-2017, 02:32 AM   #2
mike42
mike42's Avatar
Default Re: Who sells best master cylinder for 40
I went to local NAPA store and they have them. What was recommended to me is a rebuild as the core would be made in USA. A new one would be made off shore from where ever. I bought the rebuilt which was a few bucks cheaper and it fit perfectly in my 1940 Sedan. Works great.
Good luck.
Mike
mike42 is offline   Reply With Quote
Old 01-12-2017, 03:14 AM   #3
danliveshere
danliveshere's Avatar
Josh if you have an original then have it stainless steel sleeved and rebuilt. You can even do this with the wheel cylinders. More expensive than new replacement parts but once they're done they'll last for years especially if you keep up changing brake fluids at normal service periods. Worth the money now if you expect to keep the car for a long time to come.
danliveshere is offline   Reply With Quote
Old 01-12-2017, 12:01 PM   #4
Ford Freak
I got mine from Mac's . No problems yet after 2 yrs.
Ford Freak is offline   Reply With Quote
Old 01-27-2017, 03:02 PM   #5
tomkowal
i got mine from napa also a few years back-- no problems so far........
tomkowal is offline   Reply With Quote
Old 01-27-2017, 04:35 PM   #6
51504bat
51504bat's Avatar
Got the one in my '39 p/u from Joe's Antique Auto. It's a Wagner made in USA. No issues as opposed to the fairly new off shore one it replaced.
Old 01-30-2017, 12:26 PM   #7
josh1331
thank you wagner sounds good appreciate very much josh
Old 01-30-2017, 12:27 PM   #8
josh1331
napa is also good resource perhaps they have usa stock? thank you
Old 01-30-2017, 12:28 PM   #9
josh1331
i will save original as i have all wheel cylinders that were replaced, in case need ?thks josh
